New Go-Kart Builder
Go-Kart Maniacz
So the go kart is coming along. My order came yesterday which was:
38 inch live axle
60t sprocket
disk breaks
chain
sprocket holder
and axle bearing kit
Pictures will be coming soon!!!
Also tomorrow we are going to finish welding the frame.
And I also have the front tires.
I also have a question about rear tires
I really need help in finding a cheap but durable pair of tires to fit a live axle. Is there a place to get a pair for about 50$?
Thanks! any help is apreciated!
Sorry forgot about this thread.
What I meant was to have a keyed axle with tires having a hub with a mating keyway, aswell as using two(2) locking shaft collars to have a secure connection.
Go-Kart Maniacz
Well just wanted to update the thread. The go-kart is coming along nicely. The only thing left is to build the spindles, steering shaft weld some more bars on to the front and back for bumpers. Also I ordered the back tires and they should be here on Friday. I am adding pictures right now
Go-Kart Maniacz
Is it safe to remove the screw that stops the throttle from opening all the way on the predator 212 cc engine?
The economy variants, are just that, the cheaper versions. Go for the regular ones, they will last longer.
Right have a right hand thread, left have a left hand thread. You put a right on the right hand end of the tie rod & a left on the left hand end of the tie rod, that way, you can adjust the toe without having to disassemble the whole assembly, just loosen the lock nuts & turn the tie rod...
