Poboy kartman
Senior Moments Member
Well. ...your linkage is jacked up. ...go to jackssmallengines.com and download the manual for your engine. .....you'll need your model #.....OHH60-?????......
It will show you how the linkage should be hooked up. ...and explain how to adjust your governor. ....which I suspect needs to be done. ....
Look for the governor section in the manual.....
"One of these things is not like the others......"
