Go Kart Engine Question
Well. ...your linkage is jacked up. ...go to jackssmallengines.com and download the manual for your engine. .....you'll need your model #.....OHH60-?????......
It will show you how the linkage should be hooked up. ...and explain how to adjust your governor. ....which I suspect needs to be done. ....
Look for the governor section in the manual.....
"One of these things is not like the others......"
Duckie92
Arizona
Also the brake pedal is so hard to press nd the gas pedal is so easy to press do i have to tighten or loosen a screw for the pedals? Thankz PoBoy ill do that.
Ok, slow down, let's sort one problem at a time; I realise your anxious to drive this thing but, a little patience will go a long way; You can fix it quickly or properly, you can't have both... ;)
Relax; collectively, we'll have you kart running perfect in no time...
To answer your question re: pedals, process of elimination; to figure out where the problem is, you first need to disconnect the pedals & see if they both move freely & at the same rate; if they do, the problem lies somewhere else...
Duckie92
Arizona
Okayy. I'll do this tomorrow since its hard for me going up nd dwn the steps to go check nd to many mesquitos out there to sit outside. Yeah i have all the time in the worls now bc i got injured riding it right away bc i was to excited nd bent the steering bar to turn the wheels nd im pretty sure thats all that has to be bent bck.
Duckie92
Arizona
The website u gave me i cnt find the diagram of how its suppose to look. The model number is OHH60-71131C
Well just do this for now until we sort it out. ....use OHH50-68079G.....
It's a 5hp motor....but the linkage is identical and so is the govenor adjustment procedure. ....
Is nd even a word?? What are you trying to say?
Don't forget Duckie we are old...
too old to sp34k 1337 or know the fkn abr u kdz use these days ;)
Funny enough I really thought your a-key wasn't working properly :lolgoku:
Duckie92
Arizona
Here's some more pictures
Duckie92
Arizona
Alright i'll look in the manuel how the linkage should be and loosen up that screw. Sweet i found a picture on another forum how the linkage should be:) When i unscrew that one bolt will oil leak out? Stupid question i know but if it does i have to move my go kart to the grass area lol
Arrrrgh......young girls and monkeys. ....you're going to look at the manual now?????:lolgoku:
At least if you have a banana. ...a monkey will listen....:lolgoku:
How old are you?????? Maybe we need one of these 14 year old boys to get your attention. .....after all. ....you keep misspelling manual as Manuel?????? JK....
Duckie92
Arizona
Oh hush lol. I got the linkage off because the previous owner bent it so it couldnt go out like its suppose too.
