first kart!
r_chez_08
Should be in the shop...
Cornwall, UK
i may make some lock collars, by drilling a 3/4" hole in some 1 1/2" or so bar, and then tapping a 6mm hole in it, for an m6 to screw up tight on.
r_chez_08
Cornwall, UK
yeah lol. pics will come at the weekend. what kinda performance shall i see from the torque converter?
r_chez_08
Cornwall, UK
ok, shes all fixed up, but when i started, she would only start choked, and was bumpy at idle/ killed randomly. there is a noise when you pull the pullstart, like something is shattered inside, and i thought mabie the governor gear fell off when i disconnected the throttle, and is mashed up?
r_chez_08
Cornwall, UK
if i did remove the gov. would i have to do anything to a stock engine, or is there something else stopping it rev too high?
r_chez_08
Cornwall, UK
i found a pawl missing from my recoil, and a nut by the ignition coil(i think this caused the problem?) does a gx200 flywheel have 1 magnet or 2?
