Poboy kartman
Senior Moments Member
Ok...then I will tell you how to make it work. Post the pics.
looks like an old steering shaft off an old chev, if you cut it off, grind it down it would give more room for the engine. move the seat forward.according to the pics he needs closer to the pedals anyway.
looks like an old steering shaft off an old chev...
Looks like the 3 hole steering wheel mount is about a foot down for some reason lol.. You could just cut off the outdated (grooved) part. Then grind the nasty welds off that 3-hole mount and put it at the top where it should be... why is that mount down there??
Edit: Actually it does look extended as mckutzy said.. there must have been a good reason though, if not you could just chop off the crap that was added.
It is. It's a Corvair wheel according to the graphic on the horn button. Might be worth something (it most certainly is).
I thought the 3 hole mount was added as a "thrust washer" for the large car steering wheel but it appears it is the original wheel mount "boss". The whole splined-shaft section was added to accommodate the car wheel. I bet the car wheel made the steering effort extra light and easy.
But this is all obvious now anyway.
Great efforts at work here and the Dremel work looks first-rate!
I like that Zerk fitting on the steering column brace.![]()
I think we determined early on in this thread that it had been a Downhill "Gravity racer" in its orginal life. That explains the Brakes only and the fancy braking system.It is puzzling that there's no evidence of an engine ever being mounted to it.
