Diamonite Electrathon America Racer
The EA guidebook also has info on many different Steering systems
The Pivot Arm style, is the one we will be using
...via a steering shaft kinda like this
~14" up from the floorboard
...at the dashboard upper steering support/bushing
Goes down thru the floorboard
...kinda like this
& comes out
...thru the "saddle"
...about here
So, the Pitman Arm should "go" about here
It should be ~3" long
...same as the steering arms, on the spindles
The Tie Rods should "go" about like this
Drilled a hole, thru the "saddle'
The lower steering shaft support will be a simple Nylon Bushing (from the front wheel of a riding lawn mower)
Steering shaft, spacer & Pitman Arm
Please tell me your gonna weld the axle to your "tub side" brackets at a later time and not rely on that self taper screw to hold the axle.
That EA hand book look quite interesting. Lots of info that could be used to help explain to the newbs round here.
Hey WTR,
Good Eye!
...& yes, I am :thumbsup:
That was just to "lock 'er in place" for now :cheers2:
I used the "tub" of the mold for this "mock-up"
...but, the actual monocoque is/will be a bit bigger
...than, the mold that it was made off of (by maybe ~3/16" taller & wider)
So, once everything is transferred to the monocoque
...& I'll add a couple of welds to the inside "faces" of them side brackets (to try-n-maintain a "clean look") ;)
Yup, the Electrathon America Guidebook is "packed" with good/useful info
...& lots of info on how to do things safe(ly) :2guns:
Here is a link to the EA Guidebook (check it out) :sifone:
https://www.electrathonamerica.org/_files/ugd/032d61_12b902d9549f4ccdaac5da5c539a46d1.pdf
So, now we need (2) Tie-Rods to connect the Spindles to the steering shaft (one on each side)
So, in this application, it looks like the Tie Rods need to be ~11 1/2" long
But, we have to account for, how much "room" the Tie-Rod ends, "take up" (looks ta be ~3/4")
Clamp the piece of rod in a vise (sideways "grips" better)
...& get the appropriate Die that matches the threads of your Tie-Rod end (in this case 3/8" fine thread)
...& some cuttin' fluid (thin oil)
Make sure you align the Die nice-n-square, on the rod, when starting
Only turn the Die (clockwise) by the holder handles, ~1/4 revolution, at a time
...& then, turn the Die back (counter-clockwise) ~1/4 revolution, each a time
...this helps the cutter "clear" the debris (cut material) out of your newly cut threads :thumbsup:
Double check we have at least ~3/4" of threads (yup, just a bit over)
An installed Tie Rod end, looks like this :cheers2:
A couple of steering "details"
When doing a Pivot Arm style steering system
All of the "arms" (Pitman Arm & Spindle steering Arms) have to be oriented in the same direction
Like in the diagram "if" the steering arms on the Spindles are "pointing" rearward
...then the Pitman Arm has to be "pointing" downward
or
Like in this application, "if" the steering arms on the Spindles are "pointing" forward
...then the Pitman Arm has to be "pointing" upward
Kinda like this :thumbsup:
Another thing:
To be able to "lock-in" the Tie-Rod length (once established)
...it's best to have some extra threads (on one side)
So, a nut (not shown) can be tightened against the Tie-Rod end to "lock" the setting "in place"
&/also,
I had issues with the Tie-Rod end "binding" on/with the Spindle Arm, on hard turns, limiting the "travel"
Close up view
My solution is to just add a "spacer"
...or (2) "if" necessary ;)
A welding magnet holds the Pitman Arm, to the end of the steering shaft, nice-n-square for weldin'
Here is the Steering Linkage Assembly installed :thumbsup:
Another view
A close up view
* Notice everything is assembled with standard nuts & bolts
...are much easier ta use for "mock-ups"
But,
Stronger bolts (probably Grade 8)
...& Loc-Nuts, will be used on final assembly :cheers2:
Now let's work on the Suspension Pad holder/backer plate :cheers2:
Got out a piece of 18g. steel (same as the "saddles")
...& a piece of Aluminum (from an old sign)
Figured I'd just "go" with the steel
...& just clean 'er up & paint it
But, when I wasa puttin' the piece of Aluminum away, I "came across" a piece of Galvanized steel (from an old industrial dish washer)
...& a piece of Stainless steel (from an old refrigerator door) :idea2:
I'ma likin' the Stainless ;)
...so, I started doin' some markin'
Then, went ta cuttin'
Got 'er all cut out
...& "notched" the corners too (for bendin')
After a little "body work" :2guns:
I put the piece of stainless steel in the bender
First bend
After bendin' the (2) sides, I did a "test fit" of the "pad"
...& noticed...Um...the sides are too high?? (what wasa I thinkin'??) :mad2:
Probably only need about 1/2"
Trimmin'
Not very straight?? :furious2:
...but, the "clearance" is much better
* Note to self...fix that...later :p
Ta-da! :sifone:
"Test fit" (should "go" about here :thumbsup:
After alignin', measurin' & markin', I used a Step-drill bit to drill the mounting holes
These Button Head bolts have a smoother/rounder head than standard Hex head bolts
...& as such shouldn't affect the "pad" as much
Suspension Pad mounting plate installed
Suspension "pad" mounted on the Suspension "pad" mounting plate
Suspension Pad up against the monocoque "tub"
...while "suspending" the racer
Hard squeeze/pinch test (at max force)
I did some sandin' on the FG monocoque
Mainly where the "saddles" will mount (for now)
Cured FG is kinda "hard" on the sandpaper
...so, after a good sandin'
...I changed the paper
...& did 'er again
Now, it'sa time ta "switch" everything over
...from the "hump" of the mold
...to the FG monocoque :thumbsup:
Check for flexing here. (red)
Maybe some bracing? (Blue)
Hey WTR,
I agree "if" the monocoque was just this
But, don't ya think the rear "deck" area
...connected to the back side of the "tub"
...will reduce &/or eliminate any flexing?
...& the "flat" areas along them sides
...kinda "brace" these areas?
We have both patients, side by side
...to help ease the transfer ;)
How ta find the center of an irregular shape, like this
Let the transfer...begin :wai:
Front
Rear
Bent the side supports
Nice-n-tight
This side too
