Body mock-up with "some" wheels "spaced" ~2 1/2" above the workbench
* Hi Ducky
Um...looks like the rear wheel won't clear the "deck" that will be above it
So, I drew in an extension
Drawing of the original plan
The plan was to make & use a couple of "spines" (made outta (2) FG panels bonded to the sides of, a 1/2" foam core)
...with interlocking footboard & seatback/deck panels (also, made outta (2) FG panels bonded to the sides of, a 1/2" foam core)
...all bonded together & then, installed inside the FG body
Now I'ma workin' with a "new" idea
...ta make a (1) piece floorboard
...that has the footboard & seatback/deck "built in"
I'ma callin' it the "flyin' carpet" floorboard
* This concept should
...be a bit easier to make
...create a stiffer "inner "core"
...& provide more bonding surfaces
** It will bond all along the floorboard
...& to the upper body, in the front & rear too
