Buying a old used karting
well tapered shaft can do without keyways actually..
as opposed to a straight shaft,
where there's always play between the shaft and the bore;
a taper will -at one time- have zero play and the rest is friction ;)
The bad thing about that.. it needs to be a perfect match, and zero tolerance is really exhaustive to machine; so we're back at adding a key ;)
Miky
Croatia
While I'm waiting for the clutch, sprockets and chain I setup the brake line. I putted two springs because spring in the brake assembly is not doing it's job.
Miky,
remove the lever again and before reinstalling it; make sure the slopes are free of dents
then add a bit of white grease;
that way the lever will snap back more easily
PS the springs you added might do the job, but it's the job of the compression springs to push the lever back and grease will help them doing so ;)
Miky
Croatia
What is life without problems...
So I ordered new chain and sprockets yesterday, today package was delivered but I made a huge mistake ordering it, I didn't check diameter of big sprocket. Normally it's bigger than it needs to be, my tires are 275 mm and sprocket is 310 mm plus chain.
Question in this is can I put 9 teeth sprocket on the clutch and 52 teeth becouse this 52 sprocket is 216 mm? Next sprocket is 60 tooth and diameter is 249 mm so it has only 13 mm to the ground because the tires are 275 mm...
One picture of the kart with my kid
tyre diameter will be even less I'm afraid.. (11" are 275mm of course, but compression due to weight will reduce the effective diameter by a bit ;))
Anyways.
IF you find a 9T sprocket for the clutch... yes that still should work (5:78:1 seems okay'ish)
but there are drawbacks, a small sprocket stresses the chain mor than a bigger one;
also the power is transfered using fewer teeth so the sprocket sees more abuse too.
(4 instead of 6 doesn't sound like much but it's a 30% decrease.. thus 30% more abuse)
it'll still work,
but frankly.. you'd be better off buying a proper clutch/sprocket chain set (#35)
(12T clutch, 72T axle) if you ask me.
oh btw.. what size sprocket did you buy? 310mm... that's much more than a 64T
Correct, meaning it's a #35 sprocket...
You can safely run less than the "recommended ball park" 6:1 ratio with those small tyres; my kart has 10" tyres & runs 5:1 with no problems...
10mm is NOT 3/8" .. (that'd be 9.5something)
and since I've just seen odd metric chains I've never seen before (4mm and 5mm pitch)
I cannot say there is no such thing as a 10mm pitched chain...
I don't know if it's a measuring error (likely) or not.. diameter should be 224mm for a 72T #35
he says it's 223mm... again likely it is 3/8" but I can't tell for sure
9.252mm to be exact :D
:stir: cough cough.. EXACT??
check your math Tony.. 3/8 is .375
(so any result will either have a zero or a five as it's last digit.)
quick head conversion:
25 is 100/4 (the 25 mm)
so 37.5/4 (9.375)
and 4 times .0375 [the .4mm] (.15)
added up...
9.525mm
and my calculator says I'm correct (just checked for whatever reason ;))
(where's that tongue smiley when you really need it :() :D:D
At least you haven't been too far off :D
I tend to misplace the decimal every now and then.. and that's where it get's nasty ;)
Miky
Croatia
Question, 35# chain, will it hold becouse kart, engine and me together we have approximately 170 kilograms?
KartFab
Dallas, TX
I didnt follow this thread to know too much of the background, but even the ARC billet flywheels do not "need" a key once they are mated with the crank. The procedure for getting a good mating surface (for flywheels) is to put some valve grinding compound on the shaft, and work the flywheel left/right pushing it into the crank, clean it all up, and properly torque it down. Once mated/torqued, the friction is more than enough. Problems happen when its not torqued to spec. No idea if this is even relevant, just thought I'd share.
Miky
Croatia
I'm having trouble getting 72 tooth sprocket so I thought building a jackshaft. I have 12 tooth on the clutch, I will order 48 t sprocket for the axle and 30 the sprocket for the jackshaft in and 20 the sprocket for the jackshaft out. That gives 6:1 ratio, right? Also if I find 72 tooth sprocket hole for the key is on opposite side so I need to cut new keyhole. For the jackshaft I have an axle and bearings.
Today i got 12 t sprocket for the clutch, chain, bearings for the front wheels, spindles and axle.
That big sprocket is 72 t but it is not 3/8.
Sorry Miky,
I have to say it..
Go and just buy a setup from the US..
omb isn't that expensive at all, shipping is a pain I admit
but frankly, this is now what your third try to save shipping fees;
and all you did so far is burning money for things you didn't want.
(yes, that'd be 6:1... btw)
Know what call istra karts
www.istra-kart.com
IIRC their smaller karts run chain setups too.. they'll know a source or likely even have a spare you can buy.
if that fails
try
www.kartcross.hr
(still istria...)
and ask the same.
I think not much longer and you spend the "shipping fees" on parts you'll never going to use.
Miky
Croatia
Today got the last parts for the jackshaft. Next step is cutting peace of steel plate 30x40 cm. It will go under the engine and towards the seat. For the axle sprocket I will use old sprocket, make a seat for the new sprocket and bolt it down.
Miky
Croatia
Started cutting 4mm steel plate for the jackshaft.
As pictures shows it goes under the engine and jackshaft goes behind the seat. And yes, that is Coca-Cola air filter, it is not finished yet
