Buying a old used karting
What do you think, with or without bumpers?
I think I will leave only front and rear.
Brake caliper is the best thing on it.
I don't like huge plastic bumpers (not even front or rear),
but that's a personal preference, not advice ;)
if you like them, they do help if you hit something.
-brake caliper-?
LOL, it kinda is, care to post some close ups, so that we can see it better?
Ean Gdaniec
Muskego, Wisconsin,
I could handle a 30, but the back end would raise. My cousin put on a 23 hp turbo twin on his big body.
---------- Post added at 07:43 AM ---------- Previous post was at 07:41 AM ----------
Yeah, it most likely could take 30 hp, except the back end would lift the front, and the control would be difficult. My cousin put a 23 hp turbo twin on his big boned kart, and the front end would shoot up when he hit the gas half way.
Miky
Croatia
The frame weights 61 kilograms, here is some pictures of brake pads disassembled, I forgot to take pictures after
That thing is AWESOME!
Love it.. am I seeing that right.. purely mechanical contraption?
and scissor with NO angle compensation on the brake pads?
That's insanely stupid (but a good reason for that looooooong caliper, to keep the angle small)
Well.. you'd need to watch your brake closely for wear (the edges will be gone first)
but don't ever replace it, if you have to.. drop me a line (you know why ;))
Miky
Croatia
I thought it was the same thing, thanks.
So I will use centrifugal clutch and I want acceleration before speed.
What size sprockets do I need, engine is 8hp governed at 3600 rpm, rims are 5 inch, I don't know height of the tires. Frame weights 61 kilograms and I have 75 kilograms.
well.. it's safe to assume that the sprocket that is installed was driven by a gx270 or alike, with a 2:1 wet clutch
So, multiply by two (for the axle sprocket) and install a ten tooth clutch and you should be at least close to the ideal gear ratio :D
Miky
Croatia
The sprocket on the axle is 32 tooth and tire height is 27 centimeters.
More pictures of brake assembly
Miky
Croatia
If I'm seeing it right one of the wheels have more camber angle then other? How to check chamber angle?
remove the front wheel; put the angle onto the spindle and measure towards the upper edge of the spindle bracket... that way your floor isn't important anymore ;)
