Building a go kart size Aerial Atom
Systems Check
To connect the throttle cable to the thumb throttle, I simply drilled a hole, ran the cable thru it & used a "wire nut" as a "stop" to come in contact with &/or "trigger" it, as the cable travels :thumbsup:
Seems to work quite nicely :2guns:
Then, I did a quick check to make sure everything is functioning properly. :cool:
Made a video of the "check" too :cheers2:
https://www.youtube.com/watch?v=IWsCoyaSRdU
Tpdingo
Bellmore, NY
Well, :huh: the loaded RPM test wasn't very conclusive :mad2:
...gonna have to do 'em again :rolleyes:
The ride was really fun though :thumbsup:
First, we gotta get the battery pack, charged back up :cheers2:
I bought a 60V 2.5A SLA battery charger, last fall (~$20.00)
https://www.ebay.com/itm/60V-20AH-L...a=0&pg=2047675&_trksid=p2047675.c100005.m1851
...but, it came with the 'dreaded" C-13 DC output plug :ack2:
So, I cut 'er off
...double checked the "polarity"
…& soldered on an XT-60 plug
Then, I soldered the receptacle onto the charge wires, on the kart. :2guns:
When she's charged back up, we'll get back to testin :2guns:
While charging, I gave everything a quick "once over" :thumbsup:
...Uum, Houston we have a problem :smiley_omg:
What's wrong with this pic? :huh:
...besides ugly welds :ack2:
JTSpeedDemon
2019 Build Off Winner!
Texas
Tie rods sticking out like a red sore thumb? No end caps on frame tubing?
You know we're too lazy and/or unintelligent to play guessing games, Kevin. ;):roflol:
Nope, none of those things warrant a "Houston we have a problem" designation :rolleyes:
...gonna have ta look closer :cheers2:
Clue: a simple oversight, on my part :p
Testin';
I've been doin' some testin' :thumbsup:
RPM test results
Low gear 330 (axle speed) x 5.4 (gear ratio) = ~1,780 RPM avg.
Med gear 620 (AS) x 5.4 (GR) = ~3,240 RPM avg.
High gear 950 (AS) x 5.4 (GR) = ~5,130 RPM avg.
Speed Tests
Top speed in low gear seemed to be ~11 MPH
Top speed in med gear looked to be ~24MPH
Top speed in high gear was 35MPH :2guns:
There is more info & videos on these RPM tests in this thread
http://www.diygokarts.com/vb/showthread.php?t=41655&page=2
Here is the speed test video :2guns:
...but, had some issues toward the end :ack2:
* Sorry, the GPS screen didn't seem to record too well
...even with a zip tie :rolleyes:
…& I kinda blocked 1/2 of the "ride along" part with my shoulder :oops:
https://www.youtube.com/watch?v=IRjovx-BCJ4
