I've only heard of it being an issue in a Turbo. It of course has nothing to do with "sucking" or not... it has everything to do with hot exhaust gasses turning the impeller and poor lubrication from a weak pump or a trash plumbing job. Either way the combination seizes the bearings or turns them into shrapnel and your TC tends to become irreparably toasted.I have never in my 58 years of playing with cars heard of blowers being sucked dry of oil. I can’t even fathom how that could happen unless it was sized far too small and had to be severely over driven. Now maybe with a Paxton type supercharger that could happen. But not a Roots!!
If you've got oil in your intake there's bigger issues to worry about than an exploding forced induction unit regardless of which one it is, last I checked a twin screw charger is cooled much the same way a 2cycle engine is... the incoming A/F mix and that's assuming it generates any heat.
A centrifugal charger might be different but either way you'd plumb it like you would a TC or even an oil cooler running from a remote filter.
Low pressure line out low on the case to the filter,
Low pressure from filter to remote pump,
High pressure from remote pump to cooler (or forced induction)
High pressure from cooler (or FI) back to case above the resting oil level
Replacing the low oil sensor wire bung with a brass fitting works great since it is just above or right at where the oil level should be, and if you have an electric starter then use a 90° to route downward, and if you need to clear the mount deck without kinking the line just sttick another 90° in the first one to kick it out the left side running parallel with the starter motor.
