American Ethos (2025) Electrathon America Racer
I'm using polyester fiberglass resin (same as used in most boats)
...& the "mixing" instructions say it uses 2 oz. MEKP catalyst (activator)
...to 1 gal of resin
So, I dids me some figurin' (like Jethrow Bodine, from The Beverly Hillbillies) ;)
* Notice, I had to "break" the Gallon numbers, for the resin, down to into ounces ('cause that is how the cup is graduated)
...& the Ounce numbers for the catalyst, down into ml ('cause that is how that cup is graduated)
In the videos, they say to NOT mix up too big of a "batch" at a time
They say that a large "batch" will start "activating" (hardening up)
...before you get it all spread out :eek:
For accurate measurin' purposes, I rounded up a couple of 1q. paint mixing cups (for measurin' the resin)
...& a small medicine cup (for measurin' the catalyst) :thumbsup:
OK...Let's do this :2guns:
For a small/medium sized "batch"
...I chose 16oz of resin
...& used ~7.39ml of catalyst :cheers2:
Closer up view
Also, from my YouTube edumication
...I learned a lot from, Joe Buskin from Fish Bump TV :cheers2:
...& he recommends/uses a (2) pot method (mix in (1) cup, then pour into a shallow pan for dispensing)
* He says that having the resin "spread out" in a pan
...instead of "stacked up" in a cup
...helps to reduce any "thermic reaction" (getting hot)
...which would basically be "premature activation" :innocent::devil2:
First layer of 1708 Bi-Axial FG cloth :thumbsup:
Another view
Closer up view
I recovered all of the money they stole from me. They messed with the wrong person when they scammed me If you want to recover your funds from magnum options as well as other binary options brokers like 24options reach out to (recoveryexpert326@gmail. com) They were true to their word when they said to help recover my money from brokers They've recovered a cumulative more than $50,000
Get out of here you dyke!
Workin' on "breakin' 'er loose from the mold/form :cornut:
You can see a "color change" under the material
...as the piece separates
Worked on "loosening up" the front too :thumbsup:
A sharpie is a nice rounded "prop"
...to help "space" 'em apart
Everything was "gravy" except the fender "side walls
...as them little guys "stuck" like a sombich (technical term)
...but, I "got 'er out/off" :sifone:
Hey Denny,
Can ya "see" how it's a "mold" now? ;)
Now flip the part you just made over and wax it up and apply your mold release. Then cast a new smooth part that needs little work and minimal sanding!
Hey Denny,
"Nope...ain't gonna do it...not at this...juncture" (kinda famous phrase, do know/remember who said it?)
**Spoiler Alert**
Another view
"Whow...Nelly
...let's back up a bit"
I went back to YouTube Univ
...for some fiberglass cutting info/tips :cheers2:
This one was interesting
This one too
I gots an Oscillating Multi-Tool
...& a variety of blades :thumbsup:
These "roundy" ones have gots some really fine teeth
Hey Denny,
Yup, kinda :thumbsup:
IIRC I heard it in a movie (can't remember the name...currently) :unsure:
...& he was impersonating one of the Bushes (1 or 2)
I set up a fiberglass "cutting/sanding area"
...away from my usual "working area"
The breeze was blowing towards that "open area"
...but, I set up a fan to "help" exhaust any FG dust created...too ;)
Did some measurin' & markin'
...to help create some straight lines...for cuttin'
...usin' a piece of thin/flexible steel strip
Another view
Donned some "dashing" DIY PPG :cornut:
Yup, these fine blades, in an Oscillating tool, cut thru FG like butter :2guns:
...& like the guy in the video said " the dust just falls" &/or settles
Doesn't really "create a cloud" &/or become very "airborne"
...& was easily "brushed" into a bag for disposal :cheers2:
I got all of the edges of this floorboard/front fender "trimmed up" :thumbsup:
Then, did some soothin' on all of the edges (just hand sanded to help "keep the dust down")
...& some roundin' off, of all of the corners
Used a 1" hole saw to "cutout" some nice circles (so the top of the slots are nicely rounded)
...& then, the Multi-tool, to "cut out" the rest of the slots
Test fittin' of the fender/floorboard :thumbsup:
Looks ta be a bit "off"
Ya can see the "off-ness" even more, form this angle
I used the "pilot hole" from drilling the first 1" hole
...& then, just "off-set" the piece, a bit
...to remove the material ;)
Before
During
* See where the "saw" is cutting?
After
Another Test fit
Yup, that's a lookin' better :2guns:
Now, the top edge of that front panel, can be marked, for cuttin'
Kinda like this :sifone:
There will be more to the "roll cage", I just haven't got that far...yet ;)
Well...I have...now :thumbsup:
Lookin' down (from the front)
Lookin' down (from the rear)
Hey Ez,
Wadda ya think?
Think this "set up" will protect a helmeted & "strapped in" driver? :unsure:
