American Ethos (2025) Electrathon America Racer
The "plan" is to remodel & expand my "work area"
So, me & Ducky started off removing the mats & loose gravel
Lookie what we found
...a "sunken" slab of concrete
* Too low to be useful (anymore)
...& too high to just "lay" the bricks on
So, it had ta go
...& it didn't "go out without a fight" :ack2:
Also had to remove ~4" of gravely dirt too
This revealed
...a cut off fence post, still in concrete
...& a bunch of chunks of concrete
...& some big 'ol tree roots too :furious2:
I was doin' "double duty" (as you can see, while Ducky was takin' a brake)
...as I was workin' on the floorboard plug
...& doin' this DIY excavation too
So, while the glue was dryin'
...on the plug
...I was diggin'
While the foam was expandin'
...inside of the plug
...I was diggin'
Also, my neighbor was having a new "plastic" privacy fence put up (replacing the 30 yr old wooden fence)
...so, I installed a steel "back wall"
...to my work shelter area
...so, I couldn't "F" it up :smartass:
* I'ma expanding it a bit too ;)
...but, DON'T tell my wife
...as she, doesn't know anything about it :thumbsup:
Next for the plug was to apply some body filler (This episode brought to you...by Bondo body filler)
Here is the first/rough/base coat of body filler
Kinda like "frosting a cake" :thumbsup:
...& here is the other side
* Notice, for sanding, I am using the "remote" work table
...ta help keep the dust & mess (just like with FG) away from my usual work area :cheers2:
So, after sanding
...I applied a second coat
...mainly to the "low spots"
...left from the first coating ;)
Also, applied some body filler to help "round" them bottom junctions
After applying, I used the glass jar to help establish the "rounded" shape, of the fillets
Then, used the glass jar to help sand them "rounded" fillets
...& a sanding block for the flat stuff
Another view of "work in progress" :sifone:
Lots of sandin'
...& roundin'
...ta make this floorboard "plug"
...nice-n-smooth :thumbsup:
Then, gave 'er a couple of coats of paint
...ta "seal" everything up
Lefter view
Righter view
Check out the nice-n-rounded "fillets"
...& these "flat" areas (on the sides) will create some nice "ledges"
...ta help "stiffen/strengthen" the structure
...& for securing/mounting the floorboard, to the chassis...too ;)
I rounded these "sharp corners" off pretty goodly...too :cheers2:
Closer up view
After excavating most of the dirt (lotta work) :ack2:
...I added some Pea gravel (more work) :furious2:
Got 'er mostly smoothed out :)
I'm gonna try this Herringbone pattern :thumbsup:
* Notice, I used a "guide string" ta try-n-keep the "lines" straight
...but, found the "area" I'm working with isn't exactly square
...so, gonna have ta "work it" a bit :sifone:
** Also, started off in the garage doorway area
...so, the "patio" would be nice-n-even with the garage floor
...&/so, it wouldn't create a "trip hazard" :cheers2:
Remember when my camera got rained on, a couple of weeks ago?
Well...it seems like the "sound" recording got messed up
...& as such, I made a silent movie :thumbsup:
Let's back up a bit :cheers2:
I gave the "plug" mold (3) coats of the release wax
Then a coat of the PVA (thin plastic barrier)
Then, (1) layer of CSM (chopped strand mat) fiberglass
...& (1) layer of 1708 FG cloth
Another view
Then, (2) more layers of 1708 Bi-Axial fiberglass cloth
* Notice I re-enforced the top flange or "lip" ;)
Got 'er "cracked loose" :2guns:
...& "she's" off :sifone:
Atlanta, GA
Can you place this new component on the vehicle and show us? My feeble mind is unable to grasp it's purpose.
I sure can :cheers2:
It's a footwell/floorboard
...ta support & protect the driver's feet ;)
Here is a "test fit" on/in the chassis :thumbsup:
After I get 'er trimmed up
...the seat should almost "butt" right up to the footwell/floorboard
...as to create an almost continuous "cockpit area" :bannana:
Nice-n-tight fit :sifone:
Wow! When there is no DIYGK things get done!
Now ya need to get with carbon fiber! I wanna see that on the '26 model.
Hey T,
Yup, movin' right along
IDK about CF...maybe...just maybe :unsure:
So, I used a straight edge
...ta mark the perimeter, for cuttin' :thumbsup:
Just clean up/a little bit off the back (same thing, I always tell my barber) :smartass:
Then, used the vibratin'/ossilatin' tool
...for trimmin' off the excess ;)
I really like how using this tool, helps to keep the FG "dust down"
...& it's pretty easily cleaned up
...by just brushing it off, into the trash :cheers2:
Still workin' on the brick "work floor area"
...in between towing
...& playin' with FG :thumbsup:
A little crooked :innocent:
...but, good-n-solid :2guns:
Ducky says "Ya need ta have a "border" along this outer edge
I agreed
...&/so, "we" installed a 2 x 6 landscape timber :cheers2:
Still got a "ways" ta go
...but, I ran outta bricks
Gonna have ta go back to the brick pile "store" :smartass:
