American Ethos (2025) Electrathon America Racer
The first tab welded on "normally" nice-n-straight :thumbsup:
...but, the second tab somehow "tacked" down kinda crooked (technical term) :huh:
So, I got out my "patented" adjustable tab adjustor
...& did some adjustin' ;)
...before weldin' 'er on good-n-solid
Yup, they seem ta be lined up, pretty nicely
My "patented" adjustable tab adjustor
...also, works for adjustin' seat mounting brackets too :sifone:
Left side, rear seat back mount installed
Another view w/both brackets :2guns:
Trays & Pans
When workin' on a project
...I always try-n-use trays (or pans)
...to hold all of the parts
...for THAT project :thumbsup:
Like while doin' all of the assembly, dis-assemble & reassembly of the Nacelles
...so, nothin' gets lost &/or mis-placed ;)
I also, re-use my wife's old bakin' pans
...when she gets "fresh/new" pans
...& de-commissions the old ones
I like to use the steel pans on my drill presses
...to help "catch" the steel shavings
...& debris from drillin' :cheers2:
* I found that ya gotta "mark" em'
or
One day your wife will come out
...& "see" her pan :huh:
...& you WILL get "the look" :eek:
Then, you WILL be questioned
...about using "her pan"
...to collect steel shavings :mad2:
Even when you try-n-explain to her
...that...that is one of her old pans
...she IS still skeptical :unsure:
SO,
Now, I "mark" 'em
...with spray paint
...just a "spot" will do :sifone:
Ducky says "Whatsa ya got goin' on today?"
What's this thing?
He...he...he...do you wanna use it? :innocent::devil2:
Well...Ducky...that is a 5-n-1 scraper tool
...& it's great for removing welding debris
...especially, when building "tube" chassis :thumbsup:
They are great for general scraping
...on flat surfaces
...like coil-over shock bracket mounts
The curved area is great for scraping round surfaces
That "pointed" area is great for gettin' in them little nooks-n-crannies (technical term) :cheers2:
* Here, I'ma makin' sure that the area where the Nacelle's rubber bushings "go"
...is "nice-n-clean" before re-assembly ;)
Now, I gotta do another re-assembly
...to make sure everything still works together
...& everything "clears" everything else
...&/also, "plays together nicely"
...with the seat installed :cornut:
After cleaning the area of weldin' debris ('cause them little metal "balls" could/would damage the rubber bushings) :(
...I re-installed the Nacelle bushings
Then, re-installed the Nacelles
Profile
SAM_5028.JPGOn angle view
Yup, I'ma happy to report that everything "seems" ta be co-operatin' :banana:
Another view
More weldin' (rear Castor Wheel mount)
* I left the seat & Nacelles mounted for this weldin' procedure
...but, used an old weldin' apron
...to protect these components
Especially the plastic seat
...as it was the closest to the weldin' area :thumbsup:
Rear wheel/Castor...installed
View from the rear
Profile
Yup, it can swivel a complete 360* (if necessary)
...& clears everything...pretty well
The rear bumper will help keep 'er protected
...& functional (technical term) :cornut:
...if ever impacted from the rear (during a race)
Now/next, maybe we can "tuck" a front wheel up under here
Probably somethin' more like this :thumbsup:
* I'ma thinkin' the front wheel could just be stationary (not swivel-able)
Maybe have it "suspended" ~1/2" (hangin' up in the air...not w/suspension) ;)
So, it doesn't add extra "rolling resistance" (or drag)
...during acceleration
...or while crusin'
...&/or affect maneuverability (when steerin') :cheers2:
* This front wheel should only "come into play"
...or be used to "catch" the momentum (mass) of the vehicle
...which would make the front of the racer "dive" (go downward)
...when/while braking
What's this thing?
...on flat surfaces
But that’s only 3 uses what are the other 2?
That front wheel is awefully close to the “Crown Jewels” ain’t it?
Hey Denny,
I "nailed (3) of 'em
...so/maybe that there...my friend...is (1...or 2) of the mysteries of life :cornut:
It seems like when a driver is seated (in the drivin' position)
...the wheel would be up under the "arch" of the driver's knees (in that unused little pocket) ;)
That front wheel, would also have a fender (steel or fiberglass) over it
...as part of the floorboard :thumbsup:
&/also
This way we maintain a nice foot-well
...in the front area :cheers2:
* The floorboard will be ~3" lower than the "lower chassis rails"
...just under the bottom of the seat
Atlanta, GA
My $0.02 is make the front wheel swivel also. The front end of a vehicle can dive for a number of different reasons, if you are in the process of trying to negotiate a turn and a stationary front wheel strikes the ground, you'll probably be looking at the event upside down.
Hey Ez,
Love the "feedback"
...& appreciate the concern
...keep "it a commin" :cheers2:
For the record, Zero (~2017) was V1 of this "powered steering" concept
...motivated by (2) 36V 350W motors
...with (2) swivel Castor wheels, in the front
...& (sucky) scooter hub brakes
Land Speeder (2023) is V2 of this "powered steering" concept
...motivated by (2) 48V 1,000W motors
...with (2) stationary wheels, in the rear
...& (hard on the tires) scrub brakes
American Ethos (2025) would be V3 of this "powered steering" concept
...also, motivated by (2) 48V 1,000W motors
...but, with (1) swivel Castor, in the rear
...with (go kart style) drum brakes
...& (hopefully) better balanced :thumbsup:
(video(s) to come)
So, I'ma just tryin' some different ideas
...but/also, tryin' ta be safe about it :sifone:
"you'll probably be looking at the event upside down." :eek:
I'ma hopein' NOT :p
...but, that's totally what the driver "safety cell" (double frame rails around the driver) is for
...plus, the roll cage
* Which is specifically designed, to be able, to support the entire weight of the racer, plus the driver & battery pack
...& completely protect the drivers head too
There will be more to the roll cage
...just haven't got that far yet ;)
Also, gonna have a 5-way safety belt system
...ta help keep the driver "strapped" in the "safety cell"
...in the event of an incident
* TBH I have this same concern about a racer that
...should be able to go 25+ MPH
...without (an actual) steering wheel
Also, for the record
I'm NOT an actual "formally educated" engineer (design, electrical &/or mechanical)
...I just "play as one"
...in my back yard
...& on the internet :cornut:
FYI:
The "wheel track" (from the outside edge of (1) tire to the outside edge of the other tire)
...is ~46"
The overall length of the chassis is ~60"
So, more thoughts about the front wheel...set-up
...& placement :thumbsup:
1.) What would be the difference in "tip-ability" &/or maneuverability (in general)
..."if" the front wheel was "further back"? (toward the rear) (like I have pictured...above)
...as opposed to being closer to the front? (like right behind the front bumper) :unsure:
2.) What "if" the front wheel was
...horizontally "spring loaded"? (think about it) ;)
So, "if" the front wheel was to
...touch the ground
...in a turning situation
The front wheel would "give" a little bit (if necessary)
...& couldn't "immediately" act as a "pivot point"? :unsure::popcorn:
Ducky went "splat" :huh:
Workin' on mountin' the front wheel
I'ma thinkin' about like this :thumbsup:
* Notice the front wheel is "propped up" ~1/2" higher ;)
Another view of the "mock up"
* Notice the "alignment lines"?
...& the "areas to be cleaned" for weldin'?
Everything re-aligned
...& ready for weldin'
After tackin' & double checkin' that everything was still "in place"
...I flipped 'er over for more weldin'
* I wasa weldin' along pretty goodly
...& ran out of wire
I went & got some new wire
...but, NOW the welds are lookin' kinda crappy :furious2:
There doesn't seem to be much of any slag coverin' the welds (like usual) :eek:
WTF does that even...mean? :unsure:
Well...it means
...ta have a small spring
...on each side of the wheel :thumbsup:
So, the front wheel has the ability
...ta "slide sideways" a little bit
...if it wants ta ;)
I harvested the spring from an old Aluminum screen door
Ya know that "spring loaded catch"
...that "hangs" from the top
...to help "catch" the door when them hard wind gusts...come along
Ex.
Just had ta cut 'er in 1/2
Nice-n-even :sifone:
* Notice the "cut outs" for mountin' the axle?
Better inflate that tire to get the proper circumference before you burn it in forever like.
Hey Denny,
"We don't need no stinkin' air" :cornut:
Yup, I thought about that too :thumbsup:
The front & rear wheels are the same (rim & tire)
...& seem to have about the same height (with or without inflation)
Inflation just seems to make 'em more "bouncy" ;)
Inspector Ducky...takin' a well-deserved nap
Oops...musta woke 'er up
...while workin on a CAD floorboard
I'ma thinkin' ta have the "fender", in the middle
...with "drop downs" on either side
...& a "foot well" in the front, in the front (where the brick is)
Takin' measurements-n-notes, from the CAD mock-up
Then, transferred the "notes" to a piece of 1/8" Hardboard
Then, used a table saw to cut some "slots" or strips
