So 80 for the intake, 320 for the chamber and bling bling (white diamond rouge) for the exhaust is what I shall do!
Did I mention how awesome these Dremel Finishing Abrasive Buffs are?!!!
511E 1x180 grit, 1x280 grit.
512E 2x320 grit
These are 35k RPM, not like the 120 grit flap wheel (15k).
They fit so nicely in this head. Perfect with the micro die grinder.
Will also be using wire brush/wheel, tapered cartridge rolls (80/120 grit), 1/4" sanding drum/bands (80 grit/120 grit), wet/dry sand paper, and black/white rouge....
No...and you forgot to mention how much they cost!!!! You'll kick yourself when you see the price of whole polishing KITS at HF or Northern Tool!
Like I said BEFORE...
Those Dremel Finishing Buffs fit inside the head so NICELY, ONCE THEY HAVE ALREADY BEEN USED TO POLISH THE CHAMBER.
Ideally I would like tapered rolls 60, 80 , 120, 180, 240, 320 to fit an 1/8" mandrel???????
(for the intake and exhaust).
1/4" mandrel/tapered rolls is best I have (or could find). I wish I had finer grit (only 120), but this will be fine.
Those dremel buffs are perfect for the chamber right out of the box, so I'm glad I did that part first!
One problem with the shape of these ports is that they are not Round. They are "D" shaped. Relatively larger attachments don't fit the corners so good.
The end of a tapered sanding cartridge is perfect, but I'm topped out at 120.
HHHmmmmm???????????????
Looks like I will be mixing in hand sanding to get the corners after each of the 180, 280, and 320 stages.
One more pass with the 180 grit Dremel Finishing Buff and I'll show where I am at.
---------- Post added at 08:56 PM ---------- Previous post was at 08:35 PM ----------
And I also forgot to mention....
http://www.harborfreight.com/air-to...-cast-iron-vertical-air-compressor-61454.html
I think this is on sale for fathers day. I don't have kids, but feeling it may be worth it at this point (kids that is, just for the compressor)!
EDIT: I've come to my senses. The greatest air compressor in the world is still much cheaper than the lousiest kid!!!!! LOL
Exactly!Buy me one daddy!!!! PLEASE. PLEASE. PLEASE PLEASE.....I promise....I'll never ask you for anything else....
