I'm sorry
---------- Post added at 02:46 PM ---------- Previous post was at 02:11 PM ----------
So my little compressor will operate this micro die grinder continuously at around 40psi. Not good enough. Not enough torque to keep it spinning in tight spaces. I work for a few seconds, then wait til i get to 100psi and work some more.
So by the time these finishing buffs are the perfect size to get all the way in from the entry side, there is almost nothing left. I have a system now.
Repolish the chamber til it fits in the port, then work up the port as it gets smaller.
I've got one 320 grit left. This is it. After this, I go to hand sanding with wet paper. 220, 500, 1000, 1200 grit is what I have. So it may take some time going from 320 to 500 by hand. You see how long it takes me to go from 120 to 320 with pneumatic grinders (via 180, 280 grit). I probably didn't sprend enough time with the 180, 280 in the tight areas.
After 500, I guess it will be black emery rouge.
My system doesn't help the taper / necking nor does help get a smooth finish close to the bowl, but I'm too far along to go back to reshaping. Besides the locals are getting restless.
---------- Post added at 03:34 PM ---------- Previous post was at 02:46 PM ----------
At least 30 more things to do.
1. Finish Polishing the exhaust. - Clean Head
2. Check P2V clearancem - Clean Head
3. Decide on Gasket Thickness 0.027" or 0.045" (Will use 0.027" if P2V allows)
4. Lapp Valves - Clean Head
5. Install 26lb springs
6. Drain Oil
7. Open and Clean Crank Case
8. Inspect, Clean, Lubricate crank, cam, lifters....
9. Replace Side Cover Gasket with new one, Attach Side Cover, Fill with Oil.
10. Remove Flywheel, Check Flywheel key, Re-Attach Flywheel
11. Set Coil Gap to .030"
12. Seal Head with Head Gasket
13. Attach Carb Adapter with Gaskets
14. Attach studs to Carb Adapter
15. Attach Carb to carb adapter with new gasket
16. Attach Air Filter to Carb
17. Fan Shroud/ Recoil Starter
18. Gas tank
19. Exhaust Pipe- new gasket
20. Throttle Plate
21. Throttle Linkage
21. Set Valve Lash
22. Valve Cover - New Gasket
23. Torque Converter
24. Chain
25. Brakes
26. Jet the Carb
27. Do Wheelies
28. Remove Engine
29. Add Two Engines
30. Do Bigger Wheelies!
I'm sure I forgot some. Seems like a lot when I type my "To Do" list.
