Advanced Hemi 212cc Predator Build
Ok....
Initial thoughts..
30 series TC, original springs, original settings.
8T TC sprocket #41
60T Axle sprocket #41
Snow Hog Tires (came included) were 16's, now less - I'll have to measure by rolling the kart.
Highest RPM I got to was about 5600. That's only 10% better than I got before the overhaul with the same set up. The cam is advertised as "6000+ Torque Cam" I'll do more testing after I get things squared away. I only had the tach hooked up. I'm calculating around 39-40mph, which if correct, is about a 3.0 -3.5 increase in top speed (36 -39.5mph).
This was only first test and I didn't try to build for top end. After I fix the brakes,
I will see what the 0-30mph speed is next and see how she handles the mountain.
If after playing around some more, I still can't get a little closer to 6000 RPM, I may try to find a 72T Sprocket. 9:1 should get me above 6000 if this engine can't (also thinking about putting on 18.5" tires soon, so 9:1 will be much better.
---------- Post added at 05:51 PM ---------- Previous post was at 05:44 PM ----------
Didn't want to look for action cam so used laptop.
I image the "bush" incident would have been awesome to capture.
After that, I pushed her home. I had to fix the throttle linkage a half dozen times in 20 minutes.
Better videos to come once I locate the cam.
At least there were measurable performance gains. Hopefully once I get it running for a bit, I will know that everything is stable.
Poboy kartman
Senior Moments Member
White Settlement Texas
You need 3 billet jackshafts and one more carb....and you'll be good to go....at least in print....(in real life....a throttle cable and seat are the REAL accessories that make the ride more comfortable! ).....but....you already have them!
SAY WHAT???? OH HEEL NO! Dallas Stars baby!!!
What? You think only Yankees can play hockey?
Minnesota is finding out differently! !!!
GO STARS!!!! IT'S ON....OH YEAH! !!
This little punk from Detroit, probably part of some mini bike gang, was following me around the Cruise Ship loudly whispering "Blackhawks Suck!"
I told him he'd have to speak louder if his heckles were coming from the 90's!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
:huh: :huh: :huh: WOW!!! Did this thread derail or what!!!!! :smiley_omg: :roflol: :roflol: :popcorn: :popcorn:
Nope this thread is Great. It meanders FAR off course then like a Magnet or something it snaps back on course.
Its just BOB.
The thread changes almost as often as his...
Signature,
Title,
and Location.
Can anyone say A D D....
Even God could not Derail this thread.
Its just BOB.
Signature,
Title,
and Location.
Not my fault. The sinusoidal, astronomical expansion and contraction of the universe resonates in my belly causing fluctuations in my neurological pathways.
Look a Car!
:backtotopic:kinda, I don't want to go home to my buggy thread. It like it better here. They don't water down my drinks here.
Tie Rod Fixed. Nuts wont come off now, but angle grinder will be needed for removal. Will probably upgrade to better bolts in the future.
Adjustments made to the same wire hanger linkage and throttle cable. Going to test it out tomorrow.
I've been putting off the brakes for long enough. Maybe Tuesday I can get that bleeder screw out and see if that is my only problem.
Poboy kartman
Yep....it's official Chancer....not only is he after Uranus....he wants to cut his nuts off....
"and I'll be happy to see those nice young men in their clean white coats......and they're coming to take me away ho ho ha ha he he....."
Poboy kartman
I guarantee that bleader screw ain't you're only problem! :lolgoku: What no 60 mph in the first 50 feet?
BACK OFF! !!! Do you really wanna push this guy over the edge? ??
He might totally loose it and start collecting boost carbs and jackshafts....and we can only handle so many "jackshaftesses" at once!
Lol, No 60 in 50. I was hoping for 42mph with this set up.
AND If Denny pushes me over the edge, he is close enough without many DIYGK members in between us. A few tanks of RC Nitro Fuel will get me to Indiana fast enough!
Lol
I better behave in that case, we don't need anymore Chaghetto people around here where I live. Bad enough they got summer homes on Bass Lake.
Forgot to mention the paint on the exhaust pipe came out awful. I did fall asleep with it on the grill during the final curing stage. Watching the clock at 7:00 am after work, waiting for 7:15 to take it out. SO CLOSE! Not sure what time it was when I actually took it out. I was half asleep running though the house.
The paint was flaking off everywhere, especially on the side closest to the heat.
---------- Post added at 03:32 AM ---------- Previous post was at 03:15 AM ----------
Is that all it takes? I could threaten to move to Indiana? and you will behave?
Maybe if you lived in Alaska, some one would take such a threat seriously. But SoCal to Indiana?
Spring has sprung. The RPM ris. I wonder where all the power is?
Oil drained. About the recheck valve lash. Twist, tweak, adjust....
Let's get to 6000.
It's funny. I was talking about 108 options. After fist test ride, I decided to chop off all 108 toes.
I'll do some more testing before getting the bolt cutters out! Lol
I noticed the cam card says to set lash to 0.003" Hot, I had it set to 0.004" COLD.
I may have found some more RPM's lol
