Advanced Hemi 212cc Predator Build
like a friggin novel
I broke down and ordered the bushing. I order 3 of them. They are on the way!
I'll finally be able to get some driving in, get the engine warm, and really try to adjust the carb. I'll use this as an opportunity to test the original blue garter springs and play with the stock driven spring settings. I'll use the original belt. I still have an additional unused BLAST belt that came with the TC.
Maybe next week, I will order the white garter and yellow driven springs.
I'll play around with blue, white, and blue/white to see what I like best.
I'll order some good belts too.
I was messing around on app.kartcalc.net ... Thank you very much Officer Alex and please don't write me any speeding tickets!
Because I don't have a better guess, I put 15 HP in as Original HP.
I also guessed 225kg or 496 lbs.
I picked 6000 for max RPM (again just a number based off of Cam specs 6000+)
I threw in the numbers that would give the highest top speed out of my current options
(18.5" Tires, 10T TC Sprocket, 60T Axle Sprocket)
60+MPH! are you kidding me!!!! I might die!
I'm going to write a letter to my family on here. If you see a video of me pulling away and then don't hear from me in a week or so, please deliver that letter. lol
Max Wheel Torque 354 ft lb
Min Wheel Torque 118 ft lb
Acceleration 17 (ft/s)/s or 11.5 mph/s
Top Speed 61.15 mph :popcorn: :auto::smiley_omg::surrender:
Set up for Max Torque
15 Original HP
16" Tires
8T
60T
Max Wheel Torque 443 ft lb
Min Whee Torque 148 ft lb
Acceleration 24.5 (ft/s)/s or 16.5 mph/s :popcorn::drool5::stir::sifone::auto:
Top speed 42.31 mph :thumbsup:
These are just the extremes of the possibilities I have.
Two tire sizes and 3 TC sprocket options (8,9,10), gives too many options to count on one hand.
Throw in 3 TC garter spring options (b,w,b/w), 2 Driven spring options (green/yellow), 3 Driven spring settings....
AND NOW my family of 5 has run out of toes.:lolgoku:
108 options to choose from.:smiley_omg: so choose wisely!!
lets start cutting off some toes! lol but first...
Wheelies, burnouts, and 50 mph, right? Lets find out.
Jrgunn5150
Rudderless
I've been looking into back pressure, exhaust scavenging, and how exhaust pipe shape tunes the power band. This is my first exploration of this subject.. so feel free to chime in, correct me if wrong, or call me stupid. Just some of my notes.....
Exhaust gasses pulse out of the engine (more noticeable at low RPM)
Back Pressure is a myth? It is not needed. Exhaust velocity is important at low RPM, not back pressure.
At low RPM, exhaust velocity be should high to allow pulses of air to "Draft" behind the previous exhaust pulse.
For High Torque, Low RPM you'd want a thin exhaust pipe. This will keep Velocity up; however, at high RPM the thin pipe may cause excessive back pressure
For High RPM, you'd want a wide pipe. This keeps Back Pressure down, but lowers velocity.
At low RPM a Wide Pipe may not produce the Torque you want.
---------- Post added at 10:17 AM ---------- Previous post was at 09:31 AM ----------
How to tune 4 stroke with Fuel Screw
https://www.youtube.com/watch?v=kUw...RoRSfeJtEtw&annotation_id=annotation_33154981
Backpressure the way most people think of it is a myth, yes, otherwise we'd all go out and smash our tailpipes flat and go faster. Putting your thumb over a hose doesn't make a larger volume of water come out of it, it just speeds up a lower volume.
You have to remember, the pipe, and the port in the head, are three dimensional objects. People get hung up on diameter, but there's also length, and bends to consider. A 2" pipe, that makes an immediate 90 ° coming out of the head, is less beneficial than a 1/78 pipe, transitioning gently.
Then, you need to look at all your lift number's, and flow number's. What is your valve lift at .050", .100", what is your flow... It get's very complex lol.
Optimum Dia = Cylinder Volume X RPM
Gas Velocity X 2264
Pipe Length = V X T
RPM
V= Velocity T= Time
Exhaust V = 1700 FPS ? T = 120 Degrees
Intake V = 1100 FPS ? T = 85 Degrees
BMEP = Displacement in Cu. In
Torque Ft LBS X 150.8
All right already let's see this darned thing move! Stop the lip service and day dreaming. I'll believe it when I see it! :lolgoku:
I saw Doug was slacking in harassing.
My over posting, terrible spelling, bad English, and overall ignorance would tire any heckler. Lol
It will run SOON! Bushing shippng label created already. All in few days, we will be up and dangerous.
I'll try to keep lip service to a minimum, but of course I want to make a prediction to test performance against.
It would have come out better, but it fell in between coats. I didn't start over.
It looked nice after sanding. The final coat of paint is drying now. I guess it is BBQ tail pipe for breakfast tomorrow. Going to use the grill to cure it.
Poboy kartman
Senior Moments Member
White Settlement Texas
Get the wifey to give you a foot massage, so you can make that authentic Chicago Jones' BBQ!!!!!
Poboy kartman
OK....didn't really see the "bush" incident to which you referred...did see some kids pedaling for their lives!!!!!
Now...it's OK to eat a bush....but as the Allman Brothers say....don't eat a peach!!!
Matter of fact...back when Poboy was in high school....before the Chickfillet "Eat more Chicken " campaign.....my mantra was "Eat more bush"!!!!
Gotta go...Blue Angels are airborne now!!!!
