Ok....
Initial thoughts..
30 series TC, original springs, original settings.
8T TC sprocket #41
60T Axle sprocket #41
Snow Hog Tires (came included) were 16's, now less - I'll have to measure by rolling the kart.
Highest RPM I got to was about 5600. That's only 10% better than I got before the overhaul with the same set up. The cam is advertised as "6000+ Torque Cam" I'll do more testing after I get things squared away. I only had the tach hooked up. I'm calculating around 39-40mph, which if correct, is about a 3.0 -3.5 increase in top speed (36 -39.5mph).
This was only first test and I didn't try to build for top end. After I fix the brakes,
I will see what the 0-30mph speed is next and see how she handles the mountain.
If after playing around some more, I still can't get a little closer to 6000 RPM, I may try to find a 72T Sprocket. 9:1 should get me above 6000 if this engine can't (also thinking about putting on 18.5" tires soon, so 9:1 will be much better.
---------- Post added at 05:51 PM ---------- Previous post was at 05:44 PM ----------
Cool Vid
Didn't want to look for action cam so used laptop.
I image the "bush" incident would have been awesome to capture.
After that, I pushed her home. I had to fix the throttle linkage a half dozen times in 20 minutes.
Better videos to come once I locate the cam.
At least there were measurable performance gains. Hopefully once I get it running for a bit, I will know that everything is stable.
