Advanced Hemi 212cc Predator Build
I'll start another thread on it, I didn't mean to jack your awesome thread lol.
Don't worry! lol
Post what ever you want here! It will probably help me learn something.
I was just reading DD's threads and thinking how sometimes it is good to be the dumbest person in the room....
Then I made eye contact with the dog and flushed the toilet.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Yeah. That guy is amazing. We all could learn a ton there. Last years build off entry was so informative. He had thought about everything, improved it and proved it.
The guy has built engines out of a solid hunk of metal!!!
You wanna see something else cool. Look for last years buildoff winner "Slidewayz"
Now that is a neat kart. Engineering and Art!
Jrgunn5150
Rudderless
Don't worry! lol
But if I make a separate thread it helps everyone learn lol. How's your project coming?
Slow, but that is good. Gives me time to overthink everything before I make mistakes so I can get extra mad at myself.
Since I already drilled a pilot hole in the top of the tank, I will proceed with the fuel return line installation.
Fuel line fits nicely in a grommet I found. D =5/8", ID = 0.477", OD = 51/64", Thickness = 0.060"
What I don't have is a 5/8" drill bit.
I will get a high speed steel step drill bit soon and have at it.
I positioned the fuel filter after the T, but before the carb. I wanted it before the fuel pump, but fitting it there was going to be an issue with the throttle. Better before the carb than nothing.
If I have issues with the pump, I will go gravity.... But since I have it, and it's ready to go, I will try it.
Poboy kartman
Senior Moments Member
White Settlement Texas
As if you need time or a reason...to OVERTHINK things!!!!
But let me ask you a question: do you ponder over and obsess as much on your mistakes as you do your planning?
Or do you just let that go....file that information in the thick skull for later....and move on....
And....Whataburger mustard goes really well with Aspergers....JK!
Planning usually involves trying to figure out the fundamentals. What, how, and especially why!
I Try to foresee problems, but mistakes often come as a " Eureka" moment and after, I understand "why" right away.
Some mistakes need to be experienced first hand. See how careful I will be from here on out tightening bolts into Al.
Lots of stuff just needs practice. Welding, Porting, Sanding...
To answer your question, NO, Not even close. But when mistakes scare me, cost me time, or cost me money.... I remember. No need to obsess on that.
Poboy kartman
Yeah...I don't have to go that far...even if ot didn't cost me time or money, if it doesn't go EXACTLY as planned, I'll remember why, but not let it bother me, but file it away for next time!
I think I've made every mistake known to man in my lifetime so far, but very few more than once! !!!
For example... Just concerning delivery to carb... After tons of questions and research...
Will there be too much pressure?
Will pump pressure plus gravity (high tank) combine?
Will I be able to adjust it to perfect amount?
Will the hoses leak?
Will the grommet fitting be tight enough?
Does it even matter?
Will the pump clog up because filter is down stream?
Should I get another smaller filter to put before pump?
Is 1/4" tubing too big and how it will change pressure?
Another valve on the other side of the T?
Should I get an inline Primer?
When it fails... It will be none of that. Lol
---------- Post added at 10:30 AM ---------- Previous post was at 10:23 AM ----------
I ask for input, decides what makes logical sense to me, look for others past experiences and say, "It'll be fine!!!"
EDIT: But I NEED to understand WHY before anything is close to FINE
Looks like my new trail is almost complete. Temporary road for big trucks leaves nice off road trail for little buggy!
300-400 yards at least. I haven't explored yet.
Sometimes a misunderstanding leads to false confidence which gives me the courage to proceed.
Both good/bad but always educational!
OK here is the real deal!
Not as mean and so songs yet,
BUT STILL SOUNDS MEAN AS %$#%!!!!!
1600-1650 Idle
4800 RPM @ 1:17
https://www.youtube.com/watch?v=dWS0JiLSHa8&feature=youtu.be
Let me know if link works.
---------- Post added at 03:46 PM ---------- Previous post was at 03:35 PM ----------
Oooohhh weeeeee!!!
Try not to wear out 1:05 - 1:20, but even the buggy lost a nut at 1:19?
Stuff just writes itself! lol
I've been looking into back pressure, exhaust scavenging, and how exhaust pipe shape tunes the power band. This is my first exploration of this subject.. so feel free to chime in, correct me if wrong, or call me stupid. Just some of my notes.....
Exhaust gasses pulse out of the engine (more noticeable at low RPM)
Back Pressure is a myth? It is not needed. Exhaust velocity is important at low RPM, not back pressure.
At low RPM, exhaust velocity be should high to allow pulses of air to "Draft" behind the previous exhaust pulse.
For High Torque, Low RPM you'd want a thin exhaust pipe. This will keep Velocity up; however, at high RPM the thin pipe may cause excessive back pressure
For High RPM, you'd want a wide pipe. This keeps Back Pressure down, but lowers velocity.
At low RPM a Wide Pipe may not produce the Torque you want.
---------- Post added at 10:17 AM ---------- Previous post was at 09:31 AM ----------
How to tune 4 stroke with Fuel Screw
https://www.youtube.com/watch?v=kUw...RoRSfeJtEtw&annotation_id=annotation_33154981
