Advanced Hemi 212cc Predator Build
http://www.ebay.com/itm/18cc-Clone-...4d6b984&pid=100005&rk=1&rkt=5&sd=272207118185
"Just in!
18cc JT Casting, bare head (valve train sold separately)
Get a nice bump in compression from the stock clone or Predator head for LESS THAN IT COST TO MILL! ... AND you keep the piston-to-valve clearance!!
This is an amazing deal!
Visit our Clone Engine Parts Online Facebook page for upcoming events, special pricing, and find out what we're up to!"
WHAT DO YOU THINK?????
Wondering if the carb adapter would fit and if I could match the intake port to the adapter?
I think I would need a smaller intake valve to fit this head, right?. The Seat is for a 27mm valve on Hemi. The exhaust on the hemi is a 25mm valve.
Provided Piston to valve clearance checks out (hard to do without head)....
What might prevent this working?
What could I use from the Hemi 212?
What would I need new?
I tried calling around to find a shop to mill the head and nobody wanted to take my money.
cavfire
auburn, georgia
Mediocre flow stock so a mild P&P would be good, and nothing from the hemi would swap over. Dowels don't line up, but they can be run without dowel pins.
FreeRunner15
Hmmmm....Who'd a thunk it....actually opening up a valve to the correct height would help performance????
Heck with it...just throw on a couple more carbs and jackshafts, lose the weight of that unnecessary seat ....and you'll be diggin holes and doin burnouts in no time!
It really does help performance big time with the extra lift. i'm currently on a .010 intake and .012 exhaust lift with stock emulsion tube and .031 main jet and there is a big gain with it.
The drawback? it dislikes to idle so you'd need to manually idle it with your foot. Or in my case..my hand. But Bob does have a different cam and spring set than i do so he may get even more performance and spin the wheels all the way to top speed like i do.
Go ahead and try it. It isn't too excessive. i could add even more lift to it if i wanted. It's the second best free upgrade for these engines that no one talks about.
The only possible problem that i can foresee(that happened to me at a higher lift) is if you let the valve flutter at max rpm. Then there would be a possibility of the pushrod falling out of the rocker arm. Solution: just don't stay at max rpm.or use a little less lift than .012 if you're too worried about it.
Atlanta, GA
Whew boy when those pushrods fall out of the rocker arms, look out. Almost as bad as your knuckle banging into your pitman arm and scratching your taper. Then your jackshaft gets a wobble in the keyway and melts your billet mombo. That's the worst.
Your lash is set to 0.010" and 0.012"?
Stock Cam lift is around 0.225" if I remember correctly.?
What is 0.010 and 0.012?
Lash should be like 0.003". Set lash too big and valves won't open all the way, right?
Poboy kartman
Senior Moments Member
White Settlement Texas
Remember...this is a total custom built engine....ignoring any given advice anywhere....so you can't put any "stock" in any of his posts!
rk970
Coupeville, WA
A .020" increase of piston height is 1.954CC (3.5sq x 3.14 x .0508)
Stock compression is 8.5:1 (i am assuming)
So.. on the 70mmx55mm bore x stroke it needs a total of 28.2cc combustion chamber (piston height, head gasket thickness ect) for 8.5:1 CR
So .020" longer rod gives about 26.25cc chamber volume. This alone will raise the CR to 9.06:1.
Now replacing the .045 Head gasket with a .025 gets the Chamber volume down to 24.3cc and 9.7:1 CR..
Mill the head .020" total volume is now (approx) 22.34CC and 10.47 CR
I would not run tighter then .025" piston to head clearance (if you run it 8000+ rpm i would increase that number)
Anyhoo back at the ranch.. get the piston to head clearance to .025" and mill .025~30" off the head and that should get approx you target CR..
You can get a thick piece of glass and bond 60grit paper to it. Then figure eight the head on it to reduce it down .025~30. Then 100, 180, and finish wet with 220. It's getto but it works..
:thumbsup:
---------- Post added at 10:26 AM ---------- Previous post was at 10:19 AM ----------
BTW did you verify that the carb is going wide open when you mash the pedal down?
Poboy kartman
:thumbsup:
Yep....pretty much it...the one thing that I was thinking about was the head milling....I know this is a nit-picky point....but it's kinda what was in the back of my mind earlier....Now....decking the block is a straight forward reduction in volume....milling the head is not...because the combustion chamber is getting smaller at a greater rate than a constant cylinder diameter....also....(I guess I was mistaken on the piston head shape on these engines) .....but had I not been, you could see how without CCing the head before and after...complete accuracy on CR is probably not possible on paper...
It's not that it bothers me being wrong, it's just I wanted to explain my thinking at the time...and perhaps put a small bug in your ear....because people miss this when figuring CR.... (not that it really matters) ....
For all intents and purposes....your calculations will be VERY close!
rk970
Coupeville, WA
PoBoy.. yes the more you mill the head it results in diminishing returns..
He may have to take .030" off the head..
IMO Bob needs to stop throwing parts at this, and optimize what he has..
Rk
Poboy kartman
Rk
Not necessarily, on a normal head....milling might result in increased valve shrouding....but on a canted valve head...that's less of a consideration....unless, what you are getting at is too much compression!
On the second part....yeah, I agree....but he's ACTUALLY doing something!
EDIT: Oh yeah, Bob....I have a belt sander...I can mill that sucker in mere minutes!!!! (Might not be useable afterwards....but....it'll be a quick and painless death)....and your head won't suffer! LOL!
I've been thinking about trying this.^
And yes, the butterfly opens all the way. I actually am about to weld a pedal stop so it doesn't try to open any more than it should.
Ummmmm....NO....(past 90°) perhaps? IDK...Just not the solution I would come up with....IF!!!!.....(that's even the problem! )
Ok I'm going to move the pedal stop so that after the butterfly opens all the way, the throttle cable doesn't continue to pull the throttle lever - in turn pulling the wire hanger throttle linkage out of place:lolgoku:
Remember I am using the stock throttle plate rigged up in reverse. There is no more throttle stopper on the throttle plate when used this way.
Already using bottom hole on pedal so cable moves minimum with pedal motion.
---------- Post added at 04:35 PM ---------- Previous post was at 04:23 PM ----------
How about a screen door for your submarine? (Honestly, that makes no sense to me!)
My yellow sub has a screen door, but I used an entire can of Flexi-Seal (As Seen on TV) so "it'll be fine!"
machinist@large
West Michigan, 49331
That's why I suggested it...... :cheers2: :thumbsup:
:devil2: :devil2: Whats the pressure rating/ allowable depth for that???? :bannana: :D:roflol:
Poboy kartman
It really depends if it's for private....or "commercial" usage!!!!
The main thing is......it only costs about 20-30 times more to coat a screen as buy a piece of aluminum.....(and you can't weld either)....sooooo.....as Phil Shifty says: "Getchya some of that con man in a can!!!!!....." That'll cost ya thousands! !!!
So far it has held up in neighbor's kiddy pool. Tested at About 3" thus far. I'm guessing somewhere between a fathom and a league is the breaking point. I was concerned with the welds as well so I packed all seems with Gouda!\
This 212 engine is actually going to be used to power the sub. Can I enter into the contest?
machinist@large
Aaahhhhhhh!!!!!!!!
:eek: :eek: Talk about living dangerously!!!!! First it was the kid down the block that likes to play with matches (burning rubber products), but now you have to worry if he forgets to feed his mouse herd as well?!?!?! :surrender: :surrender: :surrender:
Poboy kartman
WAIT!!!!! "Gouda"...????? Isn't that that Italian knockoff of JB WELD????? "Gouda stuff?" .....Don't know if I'd trust it.....it spreads easily , but has been known to disappear overnight in areas frequented by raccoons and possums.....
(I don't know what they see in it....I've kissed a few axles in my time....and it wasn't pleasant! ) Anyway....I'm sure you'll get it all sorted out ......EVENTUALLY! .....(What's that saying: "Even a blind squirrel finds a nut .....eventually! !!!! JK!")
