JTSpeedDemon
2019 Build Off Winner!
Darn, just noticed this morning that I've got some scoring in the cylinder wall. One deeper scratch that lightly catches my nail, and a patch of light ones just enough to feel rough to my fingernail.
I can see a little bit of factory crosshatch near the top, but everywhere else in the cylinder looks a bit worn.
I think it's from me removing/installing the piston, but IDK.
Should I be concerned? Or should I hone it just to make sure?
Since it is a steel bore, I think I'd be ok with honing it, but first I want to know if it's necessary.
Main pic is just a general pic of the cylinder, and the 2 close ups are the areas of concern. 3rd pic is the one I'm most worried about.
EDIT - I was reading on the web that the rings do a small degree of self machining, and the reason why honing is important is to soften the metal so the rings can polish everything to be "just right".
So I'm just gonna put it back together once I check everything and cross my fingers. since it's a steel bore it might be OK.
