firemanjim
Just kartin' around....
You HAVE to have back brakes too. If not, you back end will swing around and be the leading end, if you have to stomp on the brake.
Use the drums up front. Since you're adding more braking power than the plans called for, you could safely assume you could down grade the rear brakes safely (within reason) User a big 5.5" drum brake like I have. Mine is from the old days of karting, but they still make them. It's by bendix......
If the front brakes are cable activated, that's to your favorites as well.... It's easier to set up and adjust front/back brake bias.
. I restored them to original paint. The cat was suspicious at first...
