Definitely have to take it to the back roads for a run. It's so awesome
Thank you
fabroman and
landuse for the advices. The 7.2:1 gear ratio is the sweet spot for this kart. My initial idea of 6:1 may not have moved the kart from a standstill on a slight slope.
A lot (A LOT) of research effort was spent for bump-steering. In practice if your wheels look parallel to each other and perpendicular to the ground then this is very good. Forget about how suspension travel changes the geometry for this kind of project
Yes, I need to use a proper throttle line instead of my improv, the break pump is leaking, the engine I suspect can run better, doesn't really matter now
The project was slightly under the budget of 6000 lei (~1500 USD) The most expensive part was the engine, sourced locally for 1300 lei (~300 USD) followed by the axle, clutch and steering rack, all imported. Fun fact: nuts&bolts cost me 150% of what I spent on the steel.
I will post another video when we go for a real test run. This is just for meeting deadline.
Cheers!
Alex
