Steering
I've achieved a lot over the last few days; steering is all but complete, just needs a slight ackermann adjustment.
I picked up a pair of tie rods a few weeks ago, complete with right & left heim joints but, they were too short so, I cut them in half, threaded the ends & set about making extensions. Starting with a length of 1/2" round bar, I drilled & tapped the ends then, after fitting a nut to each of the ends, screwed the ends into the extensions to give me the correct length. Once finished & fastened, the nuts will not only lock the assembly together but will also act as an adjusting mechanism.
Now the steering column: As you know, it was too short so, once I made the extension (as seen in post #53) I first made two plug welds in each end then seam welded the ends... it's not goin' anywhere... As the standard tie rod mounting plate made the tie rods sit too high, I also axtended the pitman arm, now they sit level & straight.
Having done all that, the steering works great but, the ackermann is out so, I also need to make a pair of adaptor plates for the spindles...
