That thing is used to float concrete floors and get them nice and level
And that's even a fairly small piece.Hey, did anyone happen to notice post #97 amongst all the banter?
Have you run the engine with the new design yet? How does it run?
I jumped the gun a bit
You have helped me finalize my decision, to own a lathe at some point in my life.
nice work on that. coming along nicely. and yes masteryota, besides a welder and drill press, my 7x12 mini-lathe is the best tool I've got. i couldn't have done half the stuff I've done at all and the rest would have looked crappy and crooked.
In the two months I've owned it, the longest I've gone without using it is about 3 days; it's definitely paid for itself...Top drawer stuff Tony- this is coming along beautifully!
I always try to get my porting done before I would have the seats redone, I don't have the steadiest of hands, and I know I will eventually knick the seat at least several times.
The mild port looks good though, and should still produce a good amount of low end torque and breathe better on the top end.
Now I can really get stuck into the engine build.I just got back from Blu-Chrome with various bits & pieces including my steering shaft, tierods, engine throttle plate, spring retainers, Ackermann brackets & a bunch of bolts, all of which are now chrome platedNow I can really get stuck into the engine build.
Also this week, I had to make a trip to the steel merchant &, while I was there, I found a piece of 2.5mm checker plate (similar to diamond plate) that, with a snip here & there, was the perfect size for the floor. About an hour of cutting, grinding & sanding & the floor is done.
I then used some 20mm x 3mm flat bar to make anchor tabs (the same as I did for the seat). Next step, weld 'em in which could be fun ATM...
Let me explain: My ex needed some wood paling fence panels cut so, yesterday while I was picking up the little princess, I cut them up for her. Not very strenuous activity but, now my back is killing me...
Pat![]()
Don't ya just love it when you finally get your parts ready, but you're too wounded to get going on the job......
I'm feeling for ya buddy!!!!Pat
Thanks Pat. Thankfully, my back got a bit better as the day went on so, I managed to tough it out & get a little bit done: Details & pics tomorrow...Chain tensioner is ingenious.
