Diamonite Electrathon America Racer
It was a beautiful holiday morning
...so, work should be slow
...& I'ma ready ta do some fiberglassin'
Then, my brother showed up
...& said, "I'm here to help you "put the roof on" your shelter area :thumbsup:
Um...so...well...we went ahead & "put the roof on" :p
Thanks bro:cheers2:
* Installed some translucent front panels too
...ta keep rain & snow out
...but, ta still let some light in ;)
Inside view
...& on the roof too (for same reason) (y)
** Also, got my new ('ol glory) flag up too :wai:
*** Now my flag will be better protected from the "elements" (wind & rain)
...& still showin' my pride in & representin' for our great country/nation :bannana::sifone:
Another view
Did have a bit of time, in the evening, ta cut the FG (1708) for the 3rd layer ;)
Cuttin' this layer in an opposing orientation/direction 🤓
Clos(er) up view
Then, layed 'er on the mold, ta do some notchin-n-fittin'
Should be able ta get 'er ta "wrap-n-lay" pretty goodly, in the back
...& up in the front too :thumbsup:
Upon re-contemplation, I went back & pre-fitted-n-notched the FG I cut, for the 2nd layer of FG
...just like I did for the FG I cut for the 3rd layer ;)
Re-cap this layer #1
Layer #2
* Took ~1 1/2 hours ta do
...& I used (4) 16 oz cups (or ~64 oz. of resin) :thumbsup:
Layer #3 "ready for duty" :thumbsup:
* Notice I added a custom/unique "watermark" :sifone:
This is a really big piece
...so, I pre-fit & aligned it ;)
Made sure it was pretty well aligned, from side-ta-side too
Ta help keep 'er aligned
...I flipped (1) end up
...& then, started "laminatin' 'er down :)
BAM!
3rd layer...done :2guns:
Those plastic cups will get soft too I’ll bet?
Hey Denny,
Whilst I wasa doin' these last (2) layers
...I did a scentifical test, betwixt the red plastic cup & the clear kind, for ya :thumbsup:
I used the clear cup (on the left) to mix up all (4) batches, for layer #2 (held up fine)
...& the clear cup on the right for (3) of the batches that I mixed up for layer #3 (also, held up fine)
...& only used the red cup for (1) batch (FAILED) :ack2:
Fun fact:
I kinda cheated :innocent::devil2:
...& checked the "specs" (recycle number) on the bottom of the cups 🤓
The red cup has a #4
...& the clear cups have a #5 on them
...indicating that they are made outta different materials
I still wasn't sure if the clear cups would "hold up" any better
...I just knew the number(s) were different :cheers2:
Well...let's see...:p
First, we "pop" this thing off
Yes, it's the "nose" lid :thumbsup:
Seemed ta come off pretty clean
Then, went ta pickin'-proddin' & a pryin' around the edges
Some snapin'-n-cracklein'-n-popin
...& we got 'er off :2guns:
Wow! that turned out, pretty kool! :sifone:
Then started pickin'-n-pryin' around the perimeter
Once everything seemed kinda loose around the edges
...so, I started applying some "lifting action/pressure from underneath, usin' the Screwjacks
I could see some lifting along the sides
...but, that "hump" wasn't "givin' up the ship" :ack2:
...& then, a couple started failing :mad2:
After ~1/2 hour of tryin'...everything
I had ta de-couple the "hump" from the "base"
Um, that wasa a lot of pressure, on them "slugs"
Looks like they all "took a hit" :cornut:
