Diamonite Electrathon America Racer
Peelin' the PVA (barrier) off the FG part
Comin' off in (1) big piece
Jualla
There are a few (a bunch) of imperfections
...& some air bubbles & "casting/mold" marks ta "deal with" ;)
...but, "we" definitely have "something" to "work with" now :thumbsup:
POOF!!
...made somethin'...outta nuthin' :2guns:
Some re-cap stuff ;)
I used ~2 gallons of resin
...~20 ft of FG cloth
...(3) roller "heads"
...(3) pans (paint tray liners)
...& (3) plastic cups, for this (3) layer, lay-up of FG
The Appliance Epoxy paint seems ta stick really well...ta everything
Creates & maintains a really hard surface
Even held up to all of the pickin' & proddin"
...that I did during de-molding :p
Inside corner of the "nose"
Along the perimeter flange
This FG piece came outta the mold
...with some pretty rough/dangerous edges
So, before doin' anything else
...let's do some trimmin'
...& clean up
First, I put/set 'er back on, the mold base (holds the piece good-n-firm & nice-n-snug)
Then, got out some PPG (gloves & glasses)
...my preferred (for this task) weapons of destruction
...& the shop vac :thumbsup:
* These oscillating tools "run" slower
...& don't seem to create the toxic FG "dust cloud"
...like the fast(er) spinny things do (like saws & cut off wheels) :cheers2:
Made pretty "quick work" of it
Popped the "nose" on
...ta help hold & help stabilize it, durin' trimmin'
...& gave me a nice trim line/guide ta work with :sifone:
Yup, that's sooooo, much better ;)
Now, just gotta do a bit of edge sandin' & smoothin' :)
Jualla
POOF!!
Those ain’t air bubbles and casting marks. Their character marks and character lines! ;)
Let's see what this "guy" weighs
Stood 'er up
...on the scale
Looks ta be ~30 lbs. :sifone:
Seems ta be pretty good/about right
...for ~2 gallons of resin
...& ~20 ft. of FG cloth :cheers2:
A quick re-cap ;)
At the beginning of last winter, I made a 1/2 scale CAD (Cardboard Aided Design) model
Then, made a full-size wooden model
...mainly working around the driver accommodations & the seat
Then, made another, full-size wooden model
...with a larger seat
...while also, refining some of the dimensions
Then, started workin' on makin' it inside out (for a plug mold) :cheers2:
Now, let's see "if" the seat actually fits :unsure:
Yes!!! :sifone:
...yes, it does...beautifully :banana:
Another view
Mock up :thumbsup:
Another view
Another kooler view :cool:
Now, we gotta figure out how we gonna mount the axle & wheels :unsure:
I got some ideas ;)
...but, am "open" to hearin' some suggestions?? :cheers2:
Notes, doodles & ideas :p
I've been thinkin' about the strength to weight ratio of potential components
Then, contemplating what materials & what thickness(es) would be best
...for makin' the other components out of :thumbsup:
So, far the strongest/beefiest parts are
...the spindle brackets, which are ~3/16" thick
...& the axle pipe/tube, which is ~1/8" thick
Also, thinkin' about
A.) makin' & incorporatin' a Saddle type structure
...for mountin' the front & rear wheel assemblies
* Saddle:
(noun) 2. A devise mounted as a support & often shaped to fit the object
(verb) 2a. To place under a burden or encumbrance
B.) Also, thinkin' about incorporatin' some side mounts too ;)
Frontal drawin'/view :)
A couple of important details, the A. strap type brackets need ta be
...bent at ~90*
...then, a roundy bend ~180*
...then, another ~90* bend
The B. mounting bracket(s) are mostly just straight
...but, need ta be welded to the axle tube
So, I went with 16g steel for the (A) bracket(s) (easier ta bend)
...& 14g. steel for the (B) bracket(s) (easier ta weld)
I got out one of my DIY metal benders
...& bent the roundy bend in the A. brackets, first
Then, clamped 'er down
...& did some "body work"
After bendin' the other side
The B. Bracket(s) just needed ta be cut out
...& then, a hole drilled in 'em
Mountin' "mock up"
I ended up makin' a few of the strap brackets
Because some didn't fit as snug as I wanted 'em to
The strap brackets would mount...about like this ;)
The side brackets would mount about like this
* I'ma gonna try-n-bend that lower "tab"
...up under the bottom...for extra strength :thumbsup:
Front axle assembly...parts
** Is this fancy & strong enough...fellas?? :unsure::unsure:
Incorporate an inner-saddle :2guns:
...wonderful suggestion ;)
I like it :thumbsup:
...& "we" will "make it so" :cheers2:
Any comments about "if" the (2) saddles should be the same size
or
Should they be staggered
...& have (1) be bigger than, the other
Drawin'
