Diamonite Electrathon America Racer
What's the need for the saddle...some may ask? :unsure:
Well...exactly what a saddle does
...spread out the load ;)
So, I did some drawin's to help illustrate :cool:
If the front axle was just mounted with the strap brackets (only)
The entire weight, of the front of the racer would be "hanging on those (4) bolts
...that are just goin' thru ~3/16" fiberglass
Would probably look like this in a very short time
...& mainly just from the weight of the racer & gravity
Then, add in some maneuverin' (from side-ta-side)
...'cause this "is" the steerin' axle
...& they would probably look like this in a very short time
Add the weight "wear" to the maneuverability "wear"
...& ya start gettin' somethin' that looks about like this
By the time ya ger 'er back to the pits
...& you'll probably have...somethin' like this (technical term: wallered out) :innocent::devil2:
Where as/by incorporatin' the saddle(s)
...them (4) bolts will now be "running" thru (4) bolt holes
...that are goin' thru (2) steel "plates"
...that will be "sandwiching" the ~3/16" FG
By designing the saddle(s) to curve under the front edge
...the (4) bolts that are mountin' the (2) strap brackets
...WILL NOT be "in shear" any longer
...& will NOW just be mainly "bolting" or "pinning" the strap brackets to the saddle(s)
* Hopefully that made sense :cornut:
Rear Saddle (CAD) work
I'ma thinkin' ta make 'er wrap around from the sides
...& wrap around from the bottom (remember its upside down) too
Transferred the "pattern' to some 18g. steel (sheet metal)
Drilled out the inner corners
...to help give us some nice rounded inner curves
* Step drill bit makes easy work of it ;)
Just gotta connect the dots :thumbsup:
Rear (outer) saddle
...all cut out :2guns:
Test fit
* Notice this saddle will "cradle" the lower rear of the monocoque "tub"
...& then, connect/attach on (6) different "planes" or directions :thumbsup:
Some may ask...why the rear saddle is so big? :unsure:
Well, it's a gonna be multi-component mount :cornut:
As the rear trailing/swing arm will mount to it
...& it's the support/backin' plate for the "pad" suspension
Plus, the roll bar
...& probably the upper, shoulder, seat belt straps too :cheers2:
Trailing arm wheel mounting plates
Let's make 'em match
Just tackin' 'em in place
Next, I drilled the axle holes
...& again, these Step drill bits make "easy work of it"
...goin' from an 1/8" pilot hole to nice-n-smooth 5/8" holes in just a couple of minutes :2guns:
you can use the next "step" to chamfer the holes a bit too ;)
We need an axle bolt (5/8" x 7" w/fine thread & a matchin' Castle nut)
...so, me & my "fair weather friend" took a ride, to the specialty bolt store :wai:
Lookin' my steel "stuff", I found a piece of 11g that should work good for mountin' the motor :thumbsup:
Rear swing/trailing arm "mock up"
Another view
While "mockin' up" the swing arm, I was thinkin' "what about ride height adjustment?"
First thought was that more (or less) of the suspension "pad" could be used to raise or lower the ride height
...but/then, thought that's kinda remedial o_O
...& "we can make 'er more elegantly adjustable" ;)
Suspension Pad mount adjustment-or solution
Goes together like this :thumbsup:
Ta look like this ;)
The ride height adjustable apparatus
...just "slides" in ta place :thumbsup:
These access holes make it easy
...ta be able ta weld the "threaded inserts" in ta place ;)
Before weldin'
...I covered up most of the "patient" :cornut:
T's online weldin' class
...also, showed me how ta do these "plug" type welds too (made it well worth the $0.99) :cheers2:
Whilst that wasa dryin' :innocent::devil2:
...I went ahead & added the last (2) re-enforcment layers of FG :thumbsup:
1.) I layed the first layer across both the front & back panels (left ta right or horizontally)
...& had 'em wrap around ~6" on both sides
2.) I layed the second layer (from front to back)
...from the "nose" to the "tail"
...goin' across the top of the first layer
So, the "hood" area
...the floorboard
...& the rear "deck" area
...all have a layer of CSM
...(2) layers of criss-crossing 1708 Bi-axial FG cloth
...& then, (2) more layers of criss-crossing 1708 Bi-axial FG cloth
For a total of (5) layers of criss-crossing fiberglass cloth
The front & back "panels" of the "hump now have
...a layer of CSM
...another (2) layers of criss-crossing 1708 Bi-axial FG cloth
For a total of (7) layers of criss-crossing 1708 Bi-axial FG cloth :2guns:
I must say, these little 4" mini-rollers make really easy work of doin' this FG stuff
...& the clean-up is even easier
Throw away the "head"
... throw the disposable roller pan liner away
...& wipe off this single-shaft-nice-n-smooth roller holder, with some Acetone :thumbsup:
Test fit of the front "saddle"
Test fit of the rear "saddle"
So, the "hood" area
...the floorboard
...a layer of CSM
I F'ed up (just a bit) :giggle:
When I posted the "above", it should have said:
"So, the "hood" area
...the floorboard
...& then, (1) more layer of criss-crossing 1708 Bi-axial FG cloth
For a total of (4) layers of criss-crossing fiberglass cloth"
"The front & back "panels" of the "hump now have
...a layer of CSM
For a total of (5) layers of criss-crossing 1708 Bi-axial FG cloth"
So, the "hood" area, floorboard(s) & rear "deck" area, all got an additional layer of 1708 Bi-axial FG cloth
...& just the front & back panels got a double layer of criss-crossing 1708 Bi-axial FG cloth :cheers2:
