Diamonite Electrathon America Racer
Hey T,
That "is" the beauty of workin with this MDF wood based material
This MDF material is very stable
...easy ta work with
...holds fasteners pretty well
...& don't produce any splinters :banana:
* I challenge ya ta get ya a sheet of 1/2"
...& play with it
...or make...somethin' :thumbsup:
** You can thank me later :cheers2: :cool:
Now back ta our regularly scheduled programmin'... :wai:
Preppin' the base for bondin' ta the "hump"
Bondin' the "hump" to the mid-section/base
* I also, used (4) 1 1/2" drywall screws
...(1) on each corner
...ta "double secure the "hump ta base" junction/connection :)
Then, added/installed/glued in some "fillet" material
...around the perimeter of the hump
I used some "gravity clamps" (bricks) ta help keep the "fillet" pieces nice-n-tight ;)
Atlanta, GA
This is what frustrates me about MDF, as long as I can see brown on the edge, it is not sealed. And with just paint it will ALWAYS show brown.
Well...let me try-n-do better on the main section :cheers2:
First gotta finish up the filleting
Then, worked on gettin' 'er sealed up
Close up of the corner (before sealin')
...which after all of this sandin'
...is kinda like "end grain"
This is what it looked like the next mornin'
Another view
A close-up view
...of the aforementioned "corner" (after sealing) ;)
A view of a lower "flat" area
...& the "junction" with the "hump'
...& the associated filleting :2guns:
* Seems ta be all ready for some sandin' & smoothin' :thumbsup:
Also, been workin' on the expansion, of my work area :sifone:
If ya remember, last summer I installed a brick floor (Herringbone pattern)
...& extended/lengthened the back wall
This year I'ma workin' on
...installin' the rest of the framework
...the roof
...a 1/2 front wall
...& extend the floor area, a bit, too :thumbsup:
Inspector Ducky checkin' on things ;)
On a sad note, "Old Glory" (my American flag) has been takin' a "beating" from Mother Nature
&/so,
Had ta be retired
..."Rest in Peace" my friend :2guns:
Roofs are kinda important glad you’re finishing it up. What about the roof on the house?
Hey Denny,
Mother Nature kinda beat up on it as well :ack2:
We had a pretty good/bad/strong "wind event" a couple of months ago
...& a couple of panels (that hadn't gotten all of their screws installed)
...got pealed up & off
They made a "hellofa racket" (like Winter wanted in...real bad) for half the night o_O
A couple got bent up...pretty goodly/badly :eek:
Some others got bent up
...& "scuffed" from gettin' beat' against the existing roofing material
I'ma just gonna replace all of these damaged panels
...a couple of hundred bucks..."down the drain" :cry:
My own "DANG" fault :mad2:
* Note to self:
Always install ALL of the screws
...in EVERY panel
...even if it starts raining & cold & windy
Doin' an inspection...the next mornin' after dryin' :cheers2:
A view of the rear area
Closer upper view, of this rear corner
Most of the fillets look pretty good
Hi...Ducky! :cornut:
Another view
* Did ya notice the "brush marks"?
I used the brush on Rustoleum Appliance Epoxy paint
...because this section is so big
...& to see if this "brush on" version gives better coverage ;)
I also, noticed that this "brush on" version has different re-coat times
...than, the spray on version :unsure:
Been workin' on sanding brush marks out of Epoxy paint :ack2:
...usin' 240 grit sandpaper
...& then, a fine Scotch Brite pad
Had ta set up a temporary roof on the shelter extension (cause of rain) :furious2:
Also, been "rounding up" FG materials (tools & supplies)
I got a powered FG cloth cutter (X-mas gift from youngest daughter) :love:
I came across these smaller (4") paint rollers (blue handle) at Home Depot
...that should be a lot easier to clean up (sticky resin) after FG work
...'cause it's just a steel shaft ;)
As the whole "head" is disposable :wai:
These smaller rollers are even kinda "padded" on the end :thumbsup:
...NOT hard plastic ends (that always scrape...something) :mad2:
Also, got (4) gallons of Polyester resin
...& (2) pieces of 1708 Bi-Axial FG cloth (50" w x 10 ft. l)
The 4" roller, came with a foam painting "roller" for smooth surfaces, on it
...but, AFAIK polyester resin "eats" most kinds of foam (that's why I got the (4) pack of the (non-foam) 3/8 " "nappy" kind) :cheers2:
So, I figured I could use the foam roller, ta apply the second coat of Appliance pain, on the main section
...FREE BONUS :wai:
* See how the "padded" tip, helps ta get "in them nooks-n-crannies"?
Here is what it looks like after a good second coat of paint
...with this "nifty" little roller :thumbsup:
Here is a close-up view
...of the aforementioned corner
...after the good, second coat of paint ;)
A view of/from the rear
Another view of/from the rear
Another thing about this little roller was "time" ;)
IIRC it took me ~45 min to brush on the first coat of paint, on the center section
...but, usin' this little roller, I "knocked" the whole thing out in like ~15 min :banana:
It seemed to "come out" so nice :)
...that I went ahead
...& "rolled" a second coat on the "nose" (took ~5 min)
Another (up closer) view
...& "tail" sections (another ~5 min)
Plugging the plugs
Used some wood filler
...ta fill the "holes" in the wood :smartass:
Left 'em out in the sunshine ta dry
...& went on a tow
Whilst I was gone
...we got a "pop up" rainstorm
...& they got kinda wet/soaked :mad2:
After re-dryin'
...& some sandin'
Before & after
I was outta the sanding sealer
...so, (plan B) I sealed 'em up with some regular 'ol black spray paint :thumbsup:
&/also
The rain/ soakin' caused some swellin' on the under side
...in the recess where the slugs/pennies go o_O
&/so
I used an End Mill type of bit
...in the Dremel
...ta "clean 'em up" ;)
That-o looks-o much-o better-o :2guns:
Double checkin' the "fit" of these "screw jacks"
...in the holes in/on the mold :thumbsup:
Double checkin' the "action" of these "screw jacks"
Gave the underside a good coat/sealin'
Gave the top side an even better coat/sealin' coat
* Notice, I didn't really try-n-coat the sides too goodly
...as ta not create a "build up" that may cause "moving/sliding &/or lifting" issues :thumbsup:
Whilst the paint wasa dryin'
...I worked on addin' some bracin' to the shelter extension
* Because, I want this outer corner to be/stay "wide open"
...as in to not have a corner "leg" or support
...right in the F'in way (technical term)
...of gettin "stuff" in/&/or/ out ;)
** Hi Ducky :)
So, I added a cross bar
...ta help support that corner
Dual diagonal bars
...coming from each direction
...ta help provide additional support
...to that corner...too :thumbsup:
Also, after usin' "it" (a damaged piece of roofing material) as a template ta mark
A replacement "piece"
I cut a piece out (of the damaged panel) to re-purpose as a half-front wall panel, on the shelter :2guns:
