What's the need for the saddle...some may ask?
Well...exactly what a saddle does
...spread out the load
So, I did some drawin's to help illustrate
If the front axle was just mounted with the strap brackets (only)
The entire weight, of the front of the racer would be "hanging on those (4) bolts
...that are just goin' thru ~3/16" fiberglass
Would probably look like this in a very short time
...& mainly just from the weight of the racer & gravity
Then, add in some maneuverin' (from side-ta-side)
...'cause this "is" the steerin' axle
...& they would probably look like this in a very short time
Add the weight "wear" to the maneuverability "wear"
...& ya start gettin' somethin' that looks about like this
By the time ya ger 'er back to the pits
...& you'll probably have...somethin' like this (technical term: wallered out)
Where as/by incorporatin' the saddle(s)
...them (4) bolts will now be "running" thru (4) bolt holes
...that are goin' thru (2) steel "plates"
...that will be "sandwiching" the ~3/16" FG
By designing the saddle(s) to curve under the front edge
...the (4) bolts that are mountin' the (2) strap brackets
...WILL NOT be "in shear" any longer
...& will NOW just be mainly "bolting" or "pinning" the strap brackets to the saddle(s)
* Hopefully that made sense
