Diamonite Electrathon America Racer
What's the need for the saddle...some may ask? :unsure:
Well...exactly what a saddle does
...spread out the load ;)
So, I did some drawin's to help illustrate :cool:
If the front axle was just mounted with the strap brackets (only)
The entire weight, of the front of the racer would be "hanging on those (4) bolts
...that are just goin' thru ~3/16" fiberglass
Would probably look like this in a very short time
...& mainly just from the weight of the racer & gravity
Then, add in some maneuverin' (from side-ta-side)
...'cause this "is" the steerin' axle
...& they would probably look like this in a very short time
Add the weight "wear" to the maneuverability "wear"
...& ya start gettin' somethin' that looks about like this
By the time ya ger 'er back to the pits
...& you'll probably have...somethin' like this (technical term: wallered out) :innocent::devil2:
Where as/by incorporatin' the saddle(s)
...them (4) bolts will now be "running" thru (4) bolt holes
...that are goin' thru (2) steel "plates"
...that will be "sandwiching" the ~3/16" FG
By designing the saddle(s) to curve under the front edge
...the (4) bolts that are mountin' the (2) strap brackets
...WILL NOT be "in shear" any longer
...& will NOW just be mainly "bolting" or "pinning" the strap brackets to the saddle(s)
* Hopefully that made sense :cornut:
Rear Saddle (CAD) work
I'ma thinkin' ta make 'er wrap around from the sides
...& wrap around from the bottom (remember its upside down) too
Transferred the "pattern' to some 18g. steel (sheet metal)
Drilled out the inner corners
...to help give us some nice rounded inner curves
* Step drill bit makes easy work of it ;)
Just gotta connect the dots :thumbsup:
Rear (outer) saddle
...all cut out :2guns:
Test fit
* Notice this saddle will "cradle" the lower rear of the monocoque "tub"
...& then, connect/attach on (6) different "planes" or directions :thumbsup:
Some may ask...why the rear saddle is so big? :unsure:
Well, it's a gonna be multi-component mount :cornut:
As the rear trailing/swing arm will mount to it
...& it's the support/backin' plate for the "pad" suspension
Plus, the roll bar
...& probably the upper, shoulder, seat belt straps too :cheers2:
Trailing arm wheel mounting plates
Let's make 'em match
Just tackin' 'em in place
Next, I drilled the axle holes
...& again, these Step drill bits make "easy work of it"
...goin' from an 1/8" pilot hole to nice-n-smooth 5/8" holes in just a couple of minutes :2guns:
you can use the next "step" to chamfer the holes a bit too ;)
