Bobs 2024 Build Off Build
This should be close to the actual build.
About 25” from floor to top of “back bone.”
Reminder: Backbone is 1x3x 1/8” x ~35”
Now I probably need some magnets and was looking at that this fixture table. It 24x36”
And it is really thin. 4mm top is close to 5/32”
I’m going over different ways to complete the frame besides the ole sawhorse shape.IMG_7024.pngIMG_7025.pngimage.jpg
Maybe a single down tube, single cradle?
Then some gusseting to support the edges of the engine mounting plate?
I think the original idea I had was a double cradle with the engine plate suspended (by weld) to the bottom of the dual cradle rails?
The steel I have for those bottom rails are pretty hefty.
1.5 x 2.5 x 1/8” IIRC
The steel I have and plan on using for down tube(s) and to connect the bottom rails to top backbone is 1” x 1.5” x 1/8”
Ya think?
Ya building a tank? Yer not going to worry about material failure are ya?
I figured most minibikes are like 1” round 0.120 wall. Square is less strong, right? So I figured as long as I used 1x1-1/2” or larger… I should be good. Plus I want to make sure it can never be moved down the stairs and outside. It’s gunna have to live in my living room for ever.
I suppose splitting the difference would be something like this…
Single down tube… Double cradle?
But pointy instead of bendy?
I do like the single down tube.
I’m gunna halfta re-measure cause I can’t re-member how tall the engine is with the stoopid charger on top.
I’m sure it’s posted somewhere in this thread but who’s gunna read 30 pages of this crap.
I know I was thinking about the 2-1/2” dimension of those bottom rails when asking how much heigth is needed from engine mount to bottom of backbone.
If I think about it…
1” pillow block bearing puts the center of the axle 36.5mm (~ 1.5”) below the bottom of the bottom rail. And 13” rear tire has 6.5” radius.
So the bottom of the bottom rail sits 8” off the ground. The top of bottom rail would sit 10.5” off the ground.
The top of backbone sits 25” off the ground
The bottom of the back one sits 22” off the ground.
Hmmm, only 14” from bottom of bottom to bottom of top???? That doesn’t seem right??
Here we go…
The height of engine plus blower is exactly equal to one chair.
So when it comes to the engine mounting plate… I only see it working with the plate mounted to the bottom of the bottom with the engine sitting between the bottom rails (as opposed to mounting the plate to the top of the rails).
Maybe put the engine on a .187 or .250 plate of the appropriate size, attach it at the rear at the desired height put a flange on the front to attach the down tube to?
that would eliminate the triangle thingy in front and keep the hardware hidden underneath.
So some sort of box thing in the rear (green line and back). Then just plate? With rear of plate welded to the box? And front of plate attached to a single down tube in some fashion?
In comparison to the photo below, there wouldn’t be any tubing along side or under the plate, but perhaps some sort of cross member behind that the plate could attach to.
