Sequoia Electrathon Racer
I made up a couple of seat "prop" mounting bars (for mounting/connecting the rear of the seat)
...made outta some 1/2" OD thin wall, steel tube (same tube as used for the A-frame bushings)
I wanted to "smash" the ends for bolting
...but, they gotta look kool!
So, I used a DIY die (I guess ya would call it) to help form a nice-n-professional curved feature
Insert the end of a piece of tube (to desired depth) into the die
Then insert the die (with tube) into a pressin' device
Then, press the sh*t out of it ;)
When done, it looks kinda like this
...& this
After some roundin'
...& adding/drilling some 1/4" bolt holes, for mounting
...then, there were (2) :sifone:
Hey T,
My eyecrometer says that wafer looks ta be a bit thicker than 1" :unsure:
...&/also, they say "if" ya scrape the mold off, it's still good inside :p
Turning a negative into a positive
The 3-wheel, hydraulic brake system that I bought, for Sequoia, came with (1) 8" (rear) rotor & (2) 5" (front) rotors
But, my plan was to switch things around
...& use (2) of the bigger 8" rotors in the front
...& then, just (1) of the smaller 5" rotors in the rear
* Reminder why:
This brake system was designed for a (Hammerhead) kart
...& they have (2) small ~10" tall front wheels
...& (2) way bigger ~20" tall rear wheels
They use (2) 5" rotors (1 on each side) to control/stop the (2) smaller 10" wheels
...& then, the (1) 8" rotor on the axle to control/stop the (2) big 'ol 20" rear wheels
Sequoia is a (3) wheeled kart, that will be running on (3) ~16" tall wheels
So, to compensate I figured 8" rotors would be a "good match" to control/stop the (2) 16" front wheels
...& then, a 5' rotor should be adequate to control/stop the (1) rear wheel
Finding an 8" rear rotor turned out to be more difficult than anticipated :popcorn:
I found out that these 8" rotors sell (individually) for ~$35.00 :furious2:
https://www.bmikarts.com/220mm-865-Brake-Rotor-for-Chinese-Go-Karts_p_35975.html
So, my frugal self, figured that it would be a better idea to just buy another whole brake kit (~$65.00)
Then, I would get the 8" rotor I needed
...& also, would have a bunch of spare parts
or
Just have to design & build another racer :auto: Tsunami :innocent::devil2:
But, when the brake kit showed up there was a big wet spot in the box :huh:
I think the plastic reservoir may have gotten stressed or even cracked
,,,but, didn't seem to leak too much when spread out on the workbench :unsure:
So, I sent the seller a message (& some pics)
...& they advised me to tighten the cap :mad2:
Nope, that was first thing I checked
...& the cap was good-n-tight :cheers2:
Then, they offered to send me an "oil can" (plastic reservoir)
...& I replied, "if" I have to fix it, I should get a discount
They offered a $10.00 discount
...& I replied that a replacement master cylinder was ~$20.00
...or (if that wasn't acceptable) I would like to return the kit for a full refund
* I was pretty sure that they didn't want their damaged brake kit, back ;)
...so yup, I ended up getting the 8" rotor I needed
...plus a bunch of spare parts (the original plan) ALL for ~$45.00 :2guns::bannana::sifone:
Proffessor of Junkology
we like to "age" our materials here @ the Mt. Top Laboratory. We leave all materials (after rough machining) out in the rain to acquire the nice patina. It also helps to reduce stress and make machining easier. (referring to the operator's stress not the material)
I have no idea why pics make that doughnut look rusty. It doesn't look that way here in "real life".
It takes 7 seconds in the Midwest for rust to form on freshly machined steel surfaces. I imagine in the great pnw it might be less.
