Sequoia Electrathon Racer
Here bees sum pickters frum wen we jus starded.
View attachment 145930 View attachment 145931
Maybe ya can git bedder idea, of what it is.
Hey T,
I used the same kinda concept (bolted a rotor to the hub of a sprocket) on my mini-Aerial Atom kart
Another view
But, for this situation the rotor flange (wood in the middle) needs to be permanently welded on to the hub
...& then, mount the rotor on to the outer side of the flange
...& the sprocket to the inner side of the flange
So, back to the wooden mock up hub
...maybe something like this
On the wheel
Side view
A closer view
I was thinking that by using a mostly blank sprocket, that maybe we can use the (6) rotor bolts
...to also, mount a DIY split sprocket (with (3) bolts on each side of the split)
* This sprocket is only for illustration purposes ('cause the center hole is too big)
There is a lot going on there and the spindle should be supported at both ends. A spindle supported on one end is possible with enough gussets extending outboard of the swing arm, and a strong enough spindle.
Hey T,
I started off contemplating just using a (longer (6") version) of a standard go kart spindle, like we are using on the front
...just have to mount it to a swing arm
...& make it stationary (so it can't turn, anymore)
Like one of these (6" x 5/8") spindles
https://www.bmikarts.com/Complete-Spindle-Set--6-x-58_p_2946.html
...or maybe just use a (well supported) ~6" 5/8 bolt on a custom swing arm
* I like your solution for the safety pins on the front hubs
...but, them (6" spindles) may also be an option for use on the front ;)
More info as to weight and horsepwer needed.
The weight of the racer should (hopefully) be ~150 lbs.
...& driver ~150 lbs.
...plus, ~30 lbs. of ballast (if entered in an EA sanctioned race)
...so, probably/hopefully in the 300 lbs. - 350 lbs. range :thumbsup:
A 48V 1,000W MY 1020 motor is rated at ~1.2HP
...or a 60V 2,000W MY-1020 brushless motor is rated at ~2.75HP :2guns:
Proffessor of Junkology
1. Why does the hub have to be welded? Rules?
2. the sprocket doesnt need to be through bolted to the rotor. Get some material with an OD big enough to use that sprocket. It can have different hole patterns on each side with threaded holes. the single point mount for the rear axle would work if ya use about a 8" SHCS. That way ya can build a 3" support on the awing arm.
weight and HP are less than l expected.
3. what is the point of 6 " spindles on the front?
1. Just thought that welding the flanges to the hub "was" the plan
2. Just thought that "if" a sprocket was being custom drilled, it would be simpler (& dual purpose) to use (1) set of bolts for mounting both components
3. Just saying that it would have been another potential solution, to the safety pin clearance issue
Tossing ideas around. Trying to use what ya have and save buck or two.
This is your project and needs to be as you like it. Feel free to tell me my ideas suck, you ain't gunna hurt my feelins. Just tell me how ya want it. I'll tell Egor and he'll just do it his way anyhow.
That driven sprocket that you salvaged off the Titanic will clean up nicely with a dip in muratic acid.
But what a goofy hole pattern...
Just another option.
Hey T,
Yup, I agree
...but, that sprocket is off of/for use with a Peerless differential from a Simplicity riding lawn mower
...is for use with #40 (pitch) chain
...& it has 68T (teeth)
We will be using #35 chain
...& something like ~50T
* Something like this
https://www.bmikarts.com/Azusa-Aluminum-Sprocket-35-Chain--4-Bolt-Circle_p_4017.html
FYI: The motor will have a 10T drive sprocket
...& the wheels have a 50T driven sprocket
...for a 5:1 GR (gear ratio)
The wheels I'm using have a circumference of ~51"
So, using the
Ballpark Equation
MS/GR=ASxTC=IM/FT=FMxHR=FHxMM= MPH
Motor Speed/Gear Ratio=Axle Speed x Tire Circumference = Inches per Minute traveled/Foot(12) = Feet per Minute traveled x Hour(60) = Feet per Hour traveled x MPH Multiplier(.000189) = Miles Per Hour
If the motor does ~3,000 RPM's
...& were running (for this example) a 5:1 gear ratio
...& the golf cart wheels have a ~51" cir.
Then, the math would look like:
3,000/5 = 600 (axle speed)
600 x 51 = 30,000 (inches per min traveled)
30,600/12 = 2,550 (feet per min traveled)
2,550 x 60 = 153,000 (feet per hour traveled)
153,000 x .000189 = 28.92 MPH :2guns:
BTW wood does not weld very well... :rolleyes:
But, it works GREAT for making quick mock-ups :thumbsup:
Ima ordered some stuff
...so, whilst wesa waitin'we'll get back to the chassis for a minute :thumbsup:
Recently (durin' the cold spell) I took an online "crash course" in aerodynamics, at the Univ. of YouTube :innocent:
...& after some edumication, I came to the conclusion that "the more ya know, the less ya wanna know"
Because it became pretty clear that my big 'ol slopin' windshield
...& "fancy" curved "bighead lookin' roofline had a massive amount of "frontal area"
Frontal view
Like, ~32" vertically
...& ~15" horizontally
...& that adds up to......Um...well...a...lot of surface area or "wetted area" (technical term)
...for the wind to be able to inflict resistance or "drag" upon :huh:
So, after a script re-write
...& some re-calculation-s
Wesa goin'/went topless :bannana:
I even aerodynamicized (new word) :p the "nose"
Here is an after "down sized" frontal view
Atlanta, GA
"Frontal area" is often unavoidable as you must have room for yourself and sufficient structure around you to keep you safe. If you wanted to pursue minimal "frontal area", you should design it so that you lay completely flat and all structure and working mechanisms are either in front of or behind you. As you can see below, it is less than ideal. Aerodynamics is a constant compromise.
Under 30 mph aerodynamics play less of a role. The best way to improve without a wind tunnel it is tape 2” pieces of yarn every couple of inches apart and drive it. Have someone film it as you do and and replay the film to see where the yarn is swirling and change the shape of the body there. Lift and downforce are also areas of concern as they too will induce drag.
Egor said he’s gunna drill the wheel flanges tomorrow. He wants me to confrim
ya want it threaded 1/2 x 20? Left hand as per the drawing? :ROFLMAO:
l’m not confirming anything, THAT has to come from the chief engineer.
Hey EZ,
Yup, I agree ;)
...& Ima not a big fan of laying down to drive
...so, Ima goin' for a "happy medium"
My thinkin' was that a drivers head/helmet
...& a roll bar (or 2) should have much less "frontal area" than the big 'ol windshield/roof that we had :thumbsup:
Don't the rules call for a "roll bar" of some sort?
Hey T,
Yup, here is an excerpt from the rulebook:
4 ROLL BAR
1. The roll bar must protect the driver's head/helmet in the event of a roll-over. It must be tall and wide enough to do this considering the full range of possible movement.
2. The roll bar structure must be triangulated with at least three legs or panel equivalent. Triangulated bracing can be either forward or rearward.With three legs bracing must extend from the top of the roll bar and securely attach to the vehicle structure, with four legs, each of the braces must extend to within 4" of the top. Any roll bar that is constructed from more than one continuous piece must be reinforced and braced triangularly from all junctions/joints in addition to the top.
3. The roll bar structure must appear to be sturdy enough to withstand the vehicle being dropped, upside down, from an altitude of one foot, with the driver inside without failure.
4. The driver’s helmet must be below a straight line drawn from the top of the roll bar to the top of the highest structural point when the driver is securely belted in driving position. (see drawing).
5. Composite or monocoque vehicles with integral rollover protection must meet comparable strength and clearance requirements.
(page 6.)
So, we'll incorporate some kinda head protection :cheers2:
I got some ideas :idea2:
Started setting up to make wheel flanges. Egor looked at the drawings and came back with the tooling.
Didn't find that 1/2 x 20 LH tap, But did find a 1/2 x 13 LH! Want to substitute?
WTF?? There was that box full of random taps I bought at that swap meet a coupla years ago...
Hey T,
I have a bunch of these, standard golf cart/boat trailer 1/2" x 20 wheel bolts :thumbsup:
Seachoice Marine Spare Wheel Bolt-1/2 X20 (5) Scp 53901
https://www.ebay.com/itm/2612470945...1622290073&itmmeta=01HQRQ8MS1S54DKPASJN6XJBVM
Think they'll be adequate for this project? :unsure:
