BrownStainRacing
- Messages
- 1,367
- Reaction score
- 1,486
You jus turned into a regular ol turd motor mechanic, did ya???Sounds like it. They just called me. They're boxing it up to ship now.![]()
Whats wrong with that big test tank??? If you could get it mounted and stable, them kids could ride for days on a tank of gas,
I noticed the throttle is not going WOT, cas the big part of cable is too long. That's an ez fix.
Also, drill a new hole for the gov spring, and move it over. Jus like the non hemi, in the same spot.
It will gain 300-400 more rpm, get the kart to moving quicker, gov will still work as it does, jus gonna start pushing back a lil later in rpm. Get all you can outta these gov'ed engines, they can handle it and last a long time.
When you get that driven off, count teeth on sprockets. If you need a change, its soooo much easier changing the top sprocket, and cheaper too.
You will figure out what gear it needs.
Looks like you have some good level smooth ground to ride on, you probably don't need to be aggressive on the gearing for 2 people.
