BrownStainRacing
- Messages
- 1,367
- Reaction score
- 1,482
K. Sounds rights. I chk tomorrow. Put it back in with sprocket, driven and nut only. See if the nylon grabs the threads.Mine is 6 - 7/16".
Yes it does. It probably will with one washer with a few chucka chuckas. It def won't with 2 though.K. Sounds rights. I chk tomorrow. Put it back in with sprocket, driven and nut only. See if the nylon grabs the threads.
You're talking about this one? I've included it every time.And no washer between nut and driven, right???
Leave it off. That's the culprit I've been looking for,You're talking about this one? I've included it every time.
Me too, lol. Thanks and g'nite.Leave it off. That's the culprit I've been looking for,![]()
That's a nylon lock nut, it don't need a washer, or too tight. Too tight will pop that snap ring off the other side of the shaft. It's a common problem with tavs. I can get into that tomorrow.
I'm headed to bed, musta had too many, lol. Ttyl
AwesomeThe bore is right. Just needs some drilling.
We gonna put the axle back in today??? Or set around doing more drinking/thinking???The bore is right. Just needs some drilling.
I'm working on it now.We gonna put the axle back in today??? Or set around doing more drinking/thinking???
Same here. My intention was to run to Lowes and get lumber for a lean-to I'm building. I still plan to go to Lowes but I'm not getting lumber today. The axle is almost finished and the 7" driven should deliver today so I can move the spring on it. I'll grab some bolts at Lowes and see if I can find 2"x2" tube. I'm still not 100% sure what I'm going to do about the mount. I reached out to the eBay seller for measurements but I doubt I'll get an answer.
I have an idea in my head that's hard to describe but I think I can make my own adjustable mount from another $25 mount plate, some tube with grooves cut in, and a little welding. I'm more confident in my welding ability when I can stand up straight and use a vice.
Well after I pulled my mini out, put it on a milk crate, got 2 bolts outta the tav cover, my dumb a$$ realized, we dont use tav covers on buggys and karts.![]()
Here ya go. It don't get no straighter then this.
And heads up, 30 series belts ONLY GO ON 1 WAY. If it's put on backwards, it will be smoked in jus a couple of mins. DO NOT ASK ME HOW I KNOW!!!!
Haha. Thanks.
Well I think I'm done for the day unless some parts come in or I decide to swim to Lowes. She's all buttoned up and blue thread locked.
What do you use to lube your axles?
Good job.
Jus regular wheel bearing grease. I usually clean old stuff out, inspect and repack.
Did you try to move that spring in the 6" driven??? To get a feel for it.
With everything I'm doing, will this thing still be capable of a slow roll or will it only snatch the tires at full throttle?
