Thepartsguy
- Messages
- 1,508
- Reaction score
- 1,388
Your not supposed to use master/half links at all. I always just use a chain break to push the pin almost all the way out. Then slip the chain back together and tap the pin back in. And peen the ends over a bit. we have loose gravel roads and grass etc.. spin donuts and just generally beat on them harsh and the chain is never a problem. it was always very problematic with master/half Links. of course the weakest links.. we do not get miles from home relying on master links. One broke on me in a parking lot and I pushed the chain against the road to split the broken link and managed to limp it home.. never again. If I had to choose between 40 chain the strongest In it’s class with a master link or 35 chain with no master link I would take 35 chain.. master links are no good. Half links worse..That's a good start. You can mock up the engine and tav and see how far you are off from the axle sprocket. If you can turn the clutch around on the crankshaft where the sprocket is on the inside, will show you where the tav sprocket will line up with the axle sprocket, jus for measuring, not running, jus mock up.
I'll check today on how much wider the 420 chain is compared to the 40 and 41, I should have some old some where. I'm concerned about the space between the back of the driven and the backing plate where the tav sprocket goes on the shaft, this area is narrow, ive had the chain hit the back of driven and backing plate causing the master link clip to break or pop off, same with 1/2 links. That's why I only use #41 chain and no 1/2 links. I have no problems at all with the narrower #41 chain when using a tav with backing plate. I'll let you know what I find.
