65ShelbyClone
I was consifering using an Aisin AMR300 as a supercharger along with E85 for a gokart build. I have to keep my mind from wondering into crazy builds. Lol
Do it. You'll have a blown hemi.
https://i.imgur.com/Ln5yFHP.jpg
You gonna make the flowbench wet-capable so you can see where the fuel is going? Something else to research at 3:30am.
Have you run across an old thesis paper yet about determining intake tuned length based on directly measuring pressure in a dead cylinder spun at running speed? I though about doing the same, but the typical sensors alone cost about a grand, not to mention the daq needed to log it at high res. What would be nice is that it could be used to evaluate head flow on an engine as well as intake effects at running speed. It would have the shortcoming of not being able to show effects of exhaust blowdown on overlap, although maybe there would be enough inertia from pumping that a correlation could be made.
You gonna make the flowbench wet-capable so you can see where the fuel is going? Something else to research at 3:30am.![]()
12.93 x 5,300 ÷ 3,456 = 19.83 CFM
At 70%VE you would need to flow about 28.4 CFM. (28.4 × .7 = 19.88)
Theoretically 19.88 CFM should be able to produce 28.63hp.
You divided 19.8 by 0.70 instead of multiplying. 19.8 × 0.7 = 13.9cfm.
I think the same thing has happened here. CFM per HP is usually estimated at 1.25-1.50; you're using 0.69. Flip the fraction and 0.69⁻¹ becomes 1.44.
13.9cfm ÷ 1.44 ≈ 9.7hp which is realistic for an ungoverned stock 212.
but I am thinking to get the biggest benifits during overlap
I have a cheap set of valve seat cutters. I hope they will be ok enough if I use them very cautiously and patiently. The pilot/guide is not tapered and there is a tiny bit of play... Which could lead to disaster. The quality ones are twice the cost that I have into the engine and flowbench. I doubt that I will use them enough to validate the purchase. And if I did buy them I know that I would end up taking apart all of my engines just to cut the valve seats to get the most out of my purchase and make it worth it lol
Does anybody have experience with the cheap Taiwan valve cutter kits that had decent results? Any tips to get good results??
I should have the last of the parts to finish up the flowbench soon. The stalling shipping times are making this build way longer than it needs to be. Most of the parts are not things that are sticked on shelves locally where I could just go and buy so I am at the mercy of the wait times we have these days. But everything is coming together nicely now so it shouldn't be too much longer.
While I have been waiting I have been contemplating building a small engine dyno as well. Stay tuned since it will more than likely be the next side project. That way I can have actual results, good or bad, about the alterations I make as well as a good way to brake in the engine and be able to vary the load while doing so.
Care to share a little on on the flow bench your building? What style? Did you use plans? How much is the flow bench costing you to build?
I have plans to build my own (been dragging *** on it for a couple years) has i have been using a buddies SuperFlow. I really need to get mine done instead of relying on him. He is getting up there in age and has a few health problems and I fear one day my access to his will be gone.
It sounds like a good plan. Let us know how it works. I have the PTS plans and i have a lot of the parts gathered to build it. I researched the simple flow benches but there seem to be accuracy and repeatability problems with most of the simple cheap flow benches. I'm sure you have found the PTS flow bench forum. It covers a lot ideas, troubleshooting, and work arounds of building and running a flow bench. I choose the PTS one to build because it was built and designed right on the forum. They only sell plans and no one is trying to make a living off it. It is also a proven design with support through the forum. I didn't want to spent too much time debugging a homemade flow bench but rather just build it and use it.
Keep us posted on how it works. At your small amount of CFMs you will be testing at it just might work. I have different applications then you and need a large flow bench that can flow 600 CFM with consistant and accurate results. I work with a lot of circle track racers so I need a bench that can flow anything from a Preditor engine to a Big Block Chevy (which takes a lot of CFMs). Also only one other person that I know of in my area has a flow bench and once the word gets out that I have one I see an opportunity to pay for mine and possibly make a little profit with it.
