Here are some pics of the cylinder tube for the flowbench
The head is on an adapter plate that 6"×6" and is lined up with a 70mm ID (the size of the cylinder bore) acrylic tube exactly where the cylinder would be that is 6" in length.
Yes. If I was concerned with how my head flows at a static rate compared to someone else's and/or wanted to put comparison numbers up for others to campare. As soon as I saw the numbers I thought they were high so I already knew that adjusting to 28" each time and posting exact 28" numbers was pointless so I just got close on a few and then wanted to see how much variance I had with the vac controller as well as get numbers at lower levels. While atmospheric pressure remains pretty constant the actual "suction" that the head goes through fluctuates greatly. After I calibrate my bench and get some more accurate numbers I will adjust to 28" at each lift and post them that way for comparison. I might do it for 10" also. But, to me, flow numbers at a single static depression is only a little bit useful. I will probably focus on numbers at higher valve events around 10"-18".
It's my opinion that the flowbench is much better suited for a data collection device rather than something that will give you hard answers on how a head will perform on a running engine. How many times will a trick head with big flowbench numbers gets out-performed by a modest head? More often than people like to admit! People want to believe that all of the time, effort and/or money was well spent and when it's not they might not admit it. Just throwing a head on a flowbench and getting a run of cfm numbers at 28" only tells you how much dry air can be pulled through at 28". It is better than nothing, for sure, but it's by far not a great indicator of actual real world performance.
After I calibrate my bench I plan on getting flow numbers at 10", 14", 18", 22", 25", 28", 30", 34", 40", 60" and dynamic with each valve lift and plot them on a chart. This way I can build a profile of the characteristics of the head and how it affects the behavior of the air flowing through it. Since there is a direct correlation between the amount of suction and cfm flow under ideal circumstances you can start to notice where a head might behave well at 10" but not gain the proper amount cfm increase at 28" as it should ideally, possibly pointing out a point that is causing too much turbulence. This way you can start to get an idea of the characteristics of what you are testing. That way when you make changes you can better understand whether or not the change was good or not and how much so. Between piston movement, fluctuating piston speeds, exhaust overlap, valve movements, sonic pressures, air/fuel speed fluctuations, etc the actual pressures are very dynamic even though the atmospheric pressure pushing in is consistent. The differences in pressures in the system can fluctuate how well and how much air can move through it at different times as well as how it behaves and alters the mixture. Sometimes you want the mixture to sheer to atomize fuel at different spots and sometimes you want it to flow smooth, sometimes it's best for it to flow smoother at higher pressure and sheer at lower pressure or vice-versa. Some times you want a good amount of swirl at certain air speeds but less swirl at higher speeds to avoid washout or fuel fling. You have to be able to get a sense of the behavior at different speeds and pressures in order to use it in a way that is actually beneficial as an aid to determine how well it will perform in real life. That way you can make changes and get an idea of how each change has affected the characteristics of the system in how it alters not only how much it can flow but if it presents any other characteristics at different speeds or pressures. Just taking a static test of 28" won't get you nearly as much information.
Since I am using very sensitive equipment for the readings over water in tubes that smootges out a lot of the fluctuations due to specific gravity, density and surface tension properties I can observe the real-time fluctuations to help get an idea if the system is more or less settled, turbulent, smooth, etc. for a better understanding of the characteristics of the system (head, port, valve seat area, exhaust, etc) that I am testing and watch it smooth out or become more more unstable with each little adjustment. I will make symbolic or numeric notes to keep track of these as well.
While it's good to have a comparative number that is representative of the average atmospheric pressure I think that if that's all you test at or look at when considering a part then you are missing out on a lot of important information that is much more detrimental to how a part would perform. If you put two heads on a flowbench that flowed exactly the same numbers throughout the valve lifts at 28" they can still perform much different in real life on the same engine. Now if you flowed them at 10" and 35" along with the 28" you would see differences in numbers at 10" and 35" even though they flowed identical at 28". Now if you use the flowbench as a data collection device and flow many at many different depression rates you can start to back engineer what a better performing head for a particular engine would present characteristically and make adjustments in those areas to make real world gains/efficiencies.
Thats my point. 28" is the standard for testing to achieve consistent flow numbers and to compare flow numbers. You are right 28" is 1 psi and every valve lift should be tested at 28". Every size orfice you flow will not be 28" of pressure but your machine should increase or decrease so you can take your CFM reading at 28".
Carbs are flow tested using 20.4" because the carb manufacturers are looking at the fuel/ air ratio the and engine needs. Not just air flow. Someone back in time (much smarter then me! LOL) decided that 20.4 was a corrected value to test and market carburetors at.
I would take the going by sound with a grain of salt. Years ago I was at the guy's shop that has the flow bench and another gentleman was there claiming the numbers mean nothing and the sound was more important. Well the flow bench owner quickly did a demo for us that proved that is not always the case. Made a believer out of me and the other guy. It still is of importance, but its not the only thing you should be going by. If it was why even have any gauges? LOL Back to the testing at 28". This is the way I was taught and seems to be when someone is stating flow number they are usually at 28" just the way I learned and the way I always did it.
Dyno are another can of worms! We have engine builders on both sides of the state here. The dyno numbers that come from the westside of the state are always higher then the eastside of the state! Yet the east motors will equal or out perform the west engines.Higher numbers sell and I will leave it at that.
As for the sound thing I think it is more about the guy working on the same head and port design for the same engine and the difference between the alterations made would be better detected by a well trained ear, especially since tge actual flow numbers when fine tunning don't actually move much. It's a fine tunning thing on heads for engines that you are very familiar with. So a builder will figure out what combo works for cars on each track and to the driver's drive style. He builds up his arsenal of engine combinations and knows where the numbers should get close to with his exact tweaks that he does. Then when the numbers get close you fine tune by ear to get the right balance, pitch, etc. So the numbers are used but the fine tuning of the characteristics that they are looking for is not a number, but a sense of feeling that you hone in on that has more to it than any simple number can present.
In my opinion you HAVE use something other than a device that spits out a hollow number if you are dealing with things that rely on more than just numbers. Since there is way more to a great performing head compared to a sluggish performing head than just the simple numbers you can test , then without including more ways of pulling data you are just guessing. Our ears and sense of touch are very sensitive and are good devices to use to help determine many different and subtle differences. With practice they can become more useful than the simple number generating devices. Most regular people without knowing much about a car can listen to 3 different engines and tell which ones make more power in classic musclecar type set-ups. I watched my dad build engines all my life. I have witnessed him diagnose an engine he had never seen before with only his ear and figure out exactly what was wrong that others could not figure out with diagnostic tools more times than I care to try to count. To this day Richard Petty can walk up to one of his Nascar Cup cars and tell if a cylinder is running too rich or lean and point to which cylinder it is. A well trained set of human sensory modules should never be left out of the equation doing most anything in life... especially when working on or building an engine.
For instance, when you check your oil. If you take the dipstick out and look at it you can see where the oil level is and the color. That gives you some indication of fluid level, whether it might be using oil and a slight indication of age by the color. You can now wipe some off in between your fingers and feel how slippery it is to give you a much more accurate idea on the age and viscosity due to how slippery it is. Then you can smell it. You can add another layer to the age as well as possible problems by whether there is coolent or fuel in the oil by the smell it has. It could smell burndt, life fuel, like coolant, etc. How many diagnostic devices would you need to gain as much information? How long would it take to get the devices hooked up? Our senses and our brains' ability to diagnose things are phenomenal and the more you know what to focus on and the more you use the skills the better they get. They should not be underestimated IMHO.
As far as engine dynos go there are so many variables thats its pretty silly to try to have exact comparisons. Just the altitude between the west and east sides of the state could be enough for a variation in numbers. A lot can be just the testing techniques. My dad would normally have lower numbers on his dyno than others. If he put an engine on from another shop where they said it pulled X amount he would assure the person beforehand that it would probably put out less on his but that didn't mean that they were lying... he just had a dyno that read more conservative.
This scenario happened a lot with my dad's customers: My dad would dyno tune an engine for someone and give them the numbers. They would go out and run it and be very happy. But then they would talk to someone who had an engine from another place that said they could get X amount out and they would go to them to have them work on it thinking they could go even faster only to end up being slower. After taking it back to the other shop and telling them that it was worse they eventually ended back at my dad's shop to get it back to where it was. A few of them took it to the other shop just to get a dyno number for comparison sake and it would be more than what my dad told them.
The process of taking a dynamic torque measurement can be difficult to get perfect, let alone factoring in test procedures and other variables. Then you have to know what compromises to make to target the specific performance that you want. Numbers can be helpful but there are more things that goes into a properly designed performance engine than just numbers.
Here are some pics of the cylinder tube for the flowbench. There is also a gasket at the top that sticks up about 1/16th to 1/8th of an inch to be sure of an air tight seal with no leaks along the face of the head.
