2017 - El Moto
I got El Moto out today :thumbsup:
But, she was TOTALLY DEAD :ack2:
NOT just dead, "really" TOTALLY DEAD :ack2::ack2:
Nothing lit up, buzzed, clicked or anything
...so, I grabbed the MM
The 48V battery pack showed 6.2V :smiley_omg:
Then, I checked them individually
...battery #1 (@ the positive output connection) showed 1.5V
...#2 showed 3.3V
...#3 showed 5.4V
...#4 (@ the negative out put connection) showed -3.9V
(seriously, it showed a minus)
(negative voltage, a new one on me)
So, yup
...I think I killed 'em :oops: & :censored:
I had the main cut-off, turned off while it was in storage for the winter
...but, yup another :censored: up
It seems that I didn't wire the DC to DC inverter to the cut-off switch
...I wired it straight to the battery pack
...it must have been drawin' a small amount of power all winter long
So, I'm guessin' (Naw, I'm pretty sure)
...that was a fatal (for the battery pack anyways) mistake
Well, can't get shook about it
...grandma always said "things happen for a reason" :cheers2:
* Note to self:
Don't do that again :lolgoku:
Learning as I go :2guns:
Ugh!!! So how much will 3 new batteries set you back?
She started off runnin' @ 36V but, now she is runnin' @ 48V
(4) 12V 35AH HF solar batteries (that's what they were) are
...~$70.00 ea. x (4) = ~$280.00 plus tax
...weigh ~20 lbs. ea. x (4) = ~80 lbs.
...for only 35AH
https://www.harborfreight.com/12-volt-35-amp-hour-universal-battery-68680.html
Maybe this is a good opportunity to move on to Lithium
I have been doin' lots of research on 'em
http://www.diygokarts.com/vb/showthread.php?t=38167
So far, I'm likin' the Chevy Volt lithium battery packs
(1) 2Kwh section is
...45V (nominal) so, I would only need (1)
...~47AH (2Kwh)
...only weighs ~45 lbs.
& seem to be plentiful in the ~$300.00 range
But, I have been reluctant to "pull the trigger"
...because there's a lot of "Very Important Details" to them
...like monitoring the balance, discharge & recharge rates & even worrying about the levels (per cell) of discharge & recharge
That's why I did all of the research & work on that STUPID Batt-Bridge
http://www.diygokarts.com/vb/showthread.php?t=38400
Still thinkin" :idea2:
Well, I did it :thumbsup:
I am the proud owner of a 2kWh section of a Chevrolet Volt lithium Ion battery
...45V 47AH ($400.00 delivered)
...as opposed to (~$300.00) for (4) 12V 35 AH SLA batteries
It's only ~9 1/2" wide x 9 1/2" deep x 10 1/2" tall
...as opposed to the ~15" wide x 10" deep x 7" tall of the SLA batteries
...so, it should fit nicely on the bike
It only weighs ~45 lbs.
as opposed to the ~80 lbs. that the SLA batteries weighed
...so, the bike should handle better & get better "mileage"
According to my research, going from a 48V 35AH "Lead" battery pack to a 45V 47AH "lithium Ion" battery pack
I should have "roughly" double the "available" power (actual usable battery capacity)
...at about half of the weight
...& it should recharge in "roughly" 1/2 of the time that the lead battery pack took :auto:
https://www.youtube.com/watch?v=ePoG8xfocEY
I have been takin' my time, this is a "whole lot of battery :cheers2:
I don't want to rush-n-mess something up
The battery pack fits in & looks great on the bike :thumbsup:
I can't even see it when sitting on the bike :2guns:
(I can just barely see it with the "gas" tank off)
Quick update
I have done lots & lots more research
First, I discovered a few things that I set up kinda wrong :ack2:
...the main power disconnect cannot be turned off (in an emergency) while riding the motorcycle (it's too far away)
...the speed controller on/off switch cannot be turned off (in an emergency) while riding, either (it's under the seat)
So, this spring, when I upgrade 'er to a 45V 2Kwh section of a Chevy Volt battery
I am going to mount a circuit breaker right on the battery lid, next to the positive (+) terminal
Reasoning:
This way it will be within reach of the rider (& eliminate a battery cable)
I am also going to (try) a 48V 150A circuit breaker, instead of the 500A fuse, that I am currently using
Reasoning:
Circuit breakers are resettable (if you blow a fuse, you better have a spare-with you)
...& I may be able to use it as a governor to help limit the amp draw
For the speed controller on/off switch
...I am going to connect the speed controller on/off wires to a relay, that's connected where the engine spark coil wires used to connect
Reasoning:
This way I can use the "stock" motorcycle off/run/off switch (on the handle bar) to turn the speed controller on/off just like "from the factory" :2guns:
...& (I have not tried it yet) but, I think, the "stock" key switch should also turn the speed controller off
...kinda like a "double safety", in case I forget :auto:
More to come
As for the stuff I did wrong :ack2:
First, I removed the on/off switch, (for the speed controller) that I previously mounted under the seat
…& ran the wires up to a relay switch (under the "tank") that's controlled by the motorcycles ignition switch
Then, I removed
...the "extra" battery cables, connecting the "main" power cut-off switch
...the cut-off switch (itself)
…& the 500A "main" power fuse
I'm gonna try a 150A circuit breaker, as a test
...as the "main" power cut-off switch
…& as the "main" power fuse too :thumbsup:
It should be the "weakest link" so, if it's "incompatible"
I "think" :idea2: it should continuously "trip" the breaker
...but, (hopefully) not harm the system
Now, we gotta figure
A way to mount the battery
...securely to the motorcycle
A place to mount the circuit breaker
...so, it's easily accessible while riding
& we need to mount a shunt ...somewhere
...for the Amp/Volt meter (to help keep an "eye" on what's happening inside of this thing)
Nothing can really be mounted "to" or "on" the battery cover
...not much room (~1/2") & open terminals (cell/pouch welds)
:idea2: Hey, what about...them "new" plastic drill boxes @ Harbor Freight?
Ya, the red ones
...they'll even match the bike :thumbsup:
Hmmmmm, just might work :wai:
...probably, have to go on the sides , not much room on top
So, to monitor, protect & use this battery "safely" were gonna use
...a circuit breaker (as a fuse & main power disconnect)
…& a "Tri-Quad" (3) meters (to monitor the internals)
I think these drill boxes (~2" thick x ~4" tall x ~6" wide) will work
...I'ma gonna give 'em a try anyways :thumbsup:
I can mount the circuit breaker, in (1) box
…& the shunt (a part of the meter circuit) in the other
:idea2: If I mount (1) box on each side
...they'll look, kinda like, (mini) saddle bags :cheers2:
So, I started with the circuit breaker
...did some markin'-n-drillin'-n-cutting
Gettin' close :2guns:
Cleaned the opening up, a bit more, with a razor knife
Yup, that should do! :thumbsup:
Looks Sweet!
Easy access
…& all connections will be connected/protected inside :cheers2:
I had to get another box for the other side
…"BONUS" it comes with "FREE" drill bits :thumbsup:
The bit holders & the cardboard inserts "pop" right out
...the stickers are kinda thick & peel off easily :cheers2:
Now, we have a good, matching & easily accessible place for the shunt :2guns:
We have some kool "mini saddle bags" to mount & protect our components
Now, we gotta get everything mounted
...the saddle bags on to the battery
…& then, the battery on to the bike
Can't (well, I guess you can, but I'm not gonna) drill any holes into
...or screw anything into the battery itself
So, we gotta use adhesive (glue) or outside pressure (clamp or strap)
First, I tried a big (36") Zip Tie, that went all of the way around the battery, thru each box & back to itself
...it kept them on but, they still "moved around" a bit :ack2:
I don't want to just "glue them on" :idea2:
...how about some "Industrial Velcro" (the extra heavy duty kind)
This way, I can "glue them in place" & they'll still removable (if ever necessary)
So, I used both :thumbsup:
...the Velcro locks them in place (no movin' around)
…& the Zip Tie is a "safety strap" (just in case) :2guns:
Now, we gotta attach the battery pack to the bike
There are (4) ~9" x 1/4" threaded rod "bolts" that go thru the entire battery that (basically) hold it together
...(2) on each side (1) above & (1) below the coolant passage way
This battery pack has a coolant running thru it when used @ ~370V in a car
...it shouldn't be necessary when only running @ ~45V
It looks like I can simply attach a piece of small "angle steel" to each end
...using the (2) lower coolant passage bolts
Gonna have to get/use some longer "thru bolts"
12" x 1/4" threaded rod (~$1.00 ea.) were a bit long
...so, (after fitting & alignment) I wacked off ~1 1/2"
I cut (2) pieces of "angle steel"
...each ~ 8 1/2"
...drilled (2) holes in each piece, that aligned with the bolts on the battery
…& bolted 'em to the battery :thumbsup:
Set it on the bike
…& got it centered & aligned
Then, marked the (4) mounting spots
...drilled the (4) 1/4" holes (2) in each piece
...smoothed the edges & cleaned 'em up a bit
A light coat of primer
…& a couple of coats of gloss black paint
Yup, that should do it! :2guns:
Now, to hook 'er up
The power starts @ the battery packs positive (+) terminal
So, I attached a piece of 4g. cable to the battery's positive terminal via 1/4" x 4g. lug & 10mm nut
…& connected the other end to the in "BATT" side of the circuit breaker via another 1/4" x 4g. lug & a 7/16" nut
Then, the power comes out of the "AUX" side of the circuit breaker
...thru another piece of 4g. cable via 1/4" lug x 4g. lug & a 7/16" nut & then connects to the contactor with a 3/8" x 4g. lug & a 17mm nut
Finally, the power comes out of the contactor via a 3/8" x 4g. lug & a 17mm nut & then connects to the B+ "bar" on the speed controller, using another 1/4" x 4g. lug & a 10mm nut-n-bolt :thumbsup:
Now, to complete the circuit
...the negative (-) connects to the speed controllers B- "bar" (1/4" x 4g. lug) thru a piece of 4g. cable
…& then connects to the P- side of the "shunt" (3/8" x 4g. lug)(mounted in the other "saddle bag")
Finally, another piece of cable connects the B- side of the shunt (3/8" x 4g.) to the negative terminal on the battery pack using a 10mm nut
* tip on cuttin' battery cables
...a cut-off tool can/will slice thru it like butter without smashing/deforming the end of the cable :cheers2:
TT540
Newb
Huntsville, AL
I love all of the repurposing and reuse. Bummer about wasting those batteries. I pull all of mine out and set them near the house garage door. Reminds me to charge them throughout the winter.
Thanks! :thumbsup:
Learning as I go (won't do that again) :cheers2:
"Everything happens for a reason"
...probably would of procrastinated another year before going Lithium
Actually, now that I think about it, I used those Harbor Freight 12V 35AH Solar batteries to power
Double Trouble https://www.youtube.com/watch?v=TRIKLdvGlTA
El Dingo (before a speed controller) https://www.youtube.com/watch?v=_5EK9EOulsY
Zero https://www.youtube.com/watch?v=Rss3YOJPBFY
El Turbo https://www.youtube.com/watch?v=H-704ZyJkaU
…& then El Moto https://www.youtube.com/watch?v=brqfLud-Ygc
Good Batteries?
Yup! :2guns:
Been thinkin' & workin' on the "Tri-Quad" meter(s) :thumbsup:
There are (3) separate gauges (~1" tall x 2" wide)
...but, its hard to fit 'em into where a 3" gauge used to go (old RPM gauge)
My buddy "Jim" @ Homers Cycle Shop gave me a couple of "make-it-yourself" gauge options, to try :cheers2:
First one looks like the back or cup for some kind of gauge
Second one looks like a chrome cover of some kind
Third is a non-functioning motorcycle speedometer (to gut, if necessary)
...or I could even "gut" the charge meter that's on the bike now
Nuthin's big enough :ack2:
(2 gauges side by side are ~4" wide)
Still thinkin' :idea2:
