2017 - !Arriba!
Picked up some 1/2" schedule 40 water pipe from Home Depot
So
...here's the plan :thumbsup:
Cut it up into several pieces
...(2) side rails
...(1) rollbar/seatback
...(1) steering support
Next
...dig out the pipe bender
Side rails (2 @ 56" ea.)
Left Rail
measure 12" - mark
measure 10" - mark
measure 20" - mark
put in bender
1. @ 12" do - 35 pumps
2. @ 22"do - 20 pumps
(inverted 180* from 1st bend)
3. @ 42" do - 75 pumps
(leaning inwards, toward 1st bend ~20*)
Right Rail
Do everything the exact same but, exactly opposite :thumbsup:
Bends came out pretty good :thumbsup:
Welded the rollbar/seat back down to the (2) side rails
& welded the curled up parts to the back side of the rollbar/seat back
Used a ratchet strap to precisely draw the sides together
Tack welded the ends of the sides to the front axle bar
That'll hold it together for now
Next, we'll square up the rear end :thumbsup:
Welded a ~16" piece of 1 1/4" angle steel across & between the side rails right where the rollbar/seatback come together
This is where the rear axle will mount & will also be the front support for the battery box :thumbsup:
The rear axle-
The original plan was to use (2) axles & (4) pillow block bearings
* RE-EVALUATE
Unnecessary & too heavy
* Exploring options :cool:
Huh. I figured the rear axle would be hanging off the back loops.
That's where the power pack & propulsion unit(s) go :thumbsup:
Goin'
...for little & big @ the same time
small foot print with lots of room
& lots of power
But, also
...lightweight & heavy duty @ the same time
I am using a minimalistic approach
& trying to make it strong by design
Goals- :2guns:
easy to enter & exit
comfortable to drive
powerful - torquey & speedy (over 20 mph)
strong but, don't over build it (keep her ~100 lbs.)
Picked up some stuff :thumbsup:
dual flanged hubs w/ 5/8" sealed bearings
6" drive wheels
72T #35 sprocket(s)
So, goin' with
15 x 6.00 - 6 rear tires & a 7.2:1 gear ratio :2guns:
Next on the agenda
Motor mount plate 3/16" x 5 1/2" x 18"
used handy dandy cut off tool to whack off the excess material :thumbsup:
WOW! 5 lbs. just for the motor mount plate :ack2:
trim the corners & clean 'er up a bit
layout a grid pattern to help keep everything square
mark & drill (2) holes for each slot
(16) holes for (8) slots
used a Dremel to connect the holes
& a 5 1/16" drill bit to smooth 'em out :2guns:
Made up a solid axle to mount the dual flanged hubs to
1 - 30" piece of 5/8" rod
2 - ~2" pieces of 3/16" angle steel (mounting brackets)
2 - ~1" pieces of 7/8" pipe (mount to hub spacer)
started by threading ~1" of each end of the rod
cleaned up a bit on wire wheel
drilled 5/8" holes in each mounting bracket to run the axle thru & 1/2" holes for mounting it to the kart
bolted the mounting brackets to the frame
run the axle thru (roughly centered)
slide a spacer on each end
slide a hub on each side
snug up with a fine threaded nut on each end
Now that everything is where it's supposed to be we can weld 'er up
just spot welds to tack everything in place
disassembled & welded 'er up good :2guns:
(don't want to get our new hubs all discolored from welding)
Now
that we know where the rear wheels go
we can get the motor mount mounted
drilled (2) 1/8" holes to tack the plate in place
to be sure nothing moves while welding
after welding
I removed the screws
& welded them holes up too :2guns:
Next up is the steering support
think were gonna go a little different direction
...than our original drawing/concept :cornut:
using the same piece we bent
...just not
a big looping nose piece
...more of just a simple support
~12" seems to be about the right height
made a couple of marks
then lined up the angle, & marked
gonna split it in half
round em' up a bit
& weld a piece of pipe between
* got some pipe that will hold these grease able bushings
they are (originally) for riding lawn mower front wheels
should work good & never squeak :thumbsup:
