2015 - Project Rocket Kart #2
rushking19
Richmond Virginia
so I called the guy who sold me the piston rings and he told me that I should file the ends of the piston rings down for it to fit what do you guys think I should do
Desertduler
When I blueprint engines I use my piston ring filer but it cuts the end of the rings flat,you would have to file half rounds in the rings also in order for the rings to fit to the orientation pins that are in the piston ring grooves,it can be done but it must be precise,on your size bore I would set the end gaps at .012 - .015 and you need a set of feeler gauges in order to measure the end gaps of the piston rings,so you would need a small flat file and a round file that is the same diameter as the orientation pins in order to do this correctly.
---------- Post added at 10:21 AM ---------- Previous post was at 09:59 AM ----------
Before you go too far have you checked that you have not spread the lower sections of your cylinder out? I bet you more than likely have, the ends of those oversized piston rings would have butted together and I am sure that you had to force the cylinders on and the reason that the cylinders would not go on any farther than you had them is because the cylinders could not expand at that point anymore because of the surrounding aluminium cylinder material.
rushking19
Richmond Virginia
He said it is the right size not over sized he said this happens all the time and I should just file it down and I got the piston free and the cylinder looks fine doesn't look like it spreaded it at all
rushking19
Richmond Virginia
Ok I filed it down a little bit it still had the Grove for the pin in the piston and I test fit it in the cylinder and it fit in perfectly I used a Old piston ring as reference and it fits perfectly so I put it on the piston and put the cylinder on no it fit perfectly I put it back together and rotated it to see if it would rotate easyly and it did, put the spark plugs in to see if it had compression and it had great compression can't wait to get it Running
Desertduler
He is full of it!:mad:
rushking19
Richmond Virginia
I finally got the Rotax 399cc Back Together ,Can't Start It Yet Because I Need To Get Screws For The Carburetor Because I Lost Them All And I Still Have To Get Pull Start Rope.But It Will Be Running Very Soon
Cool man! :wai: After all your trouble there I'm happy to hear you got it put together.:thumbsup: :popcorn:
rushking19
Richmond Virginia
Lol I'm glad to about 6 hours in the 90 degree hot sun to get here and in glad can't wait to get the rest of the parts I'm still waiting for my fan belt to come which should be any time now
Desertduler
Hey,at least you are doing something that you enjoy and you have the drive to keep moving forward with your build, part of the three "D''s as I call them,Drive,Determination and Devotion, if you follow these steps with almost anything that you do one can achieve results!
rushking19
Richmond Virginia
Thanks man I appreciate it
