2015 - Project Rocket Kart #2
rushking19
Richmond Virginia
Here's the picture of the motor and circlips I don't know the exact size of the circlips tho
Poboy kartman
Senior Moments Member
White Settlement Texas
Of course mate.....we call 'em alligator clips in America..... but they are just crocks .......:lolgoku:
No.... now I understand.....yeah....I think we do have a different name for those....(I just can't remember what we call them)..... those are VERY application specific....there is only one that is made.....and it's for that engine....there are usually other clips to get the job done....in some applications......
This is tough.....we/you....need to find exact replacement parts.....
Someone here can probably do it.....
Desertduler
Measure the wrist pins in millimeters and I will tell you what circlips will work for you,also remember that when you install those circlips make sure that the open end is either facing towards the crown of the piston or down towards the bottom of the piston skirt,not at 9 or 3 o clock. I may have a set of circlips that I will give to you if you get me the wrist pin size like I stated before.
Desertduler
Yeah....I was thinking about something else...spiral clips...but those are different....never mind me.....:furious2:
Actually some racing two stroke pistons come with spiral clips and they are pretty much bullet proof,you can get them in metric sizes but the wire circlips are less than two dollars for a pair from most places,for instance if his wrist pins are 18mm you can get a pair of Wiseco brand clips real inexpensive,the part number for them is CW18, and if the wrist pins are 20mm, the part number from Wiseco is CW20 and so on, the pins I bet are one of these sizes more than likely 18mm.
rushking19
Richmond Virginia
While I'm Waiting For The rest of my parts for my motor to come I'm designing some what how the exhaust is going to be I plan on using some of the original piping that came with the motor and my old rlv muffler I have laying ,that I'm going to cut were my finger is and weld a bigger pipe on so I can clamp it to the exhaust pipe
rushking19
Richmond Virginia
The Parts For My Snowmobile Engine Are On The Way Should Be Here By Sunday ,And Then I Can Get The Motor Running And Move On To Other Important Things Like The Drivetrain And Exhaust System
Desertduler
I am glad that you have some parts on the way,it is time to get that engine put back together and fire it up!
rushking19
Richmond Virginia
The wiseco cw18 circlips are coming today and the fan belt some time later so what I will do is install the circlips and put the seals and head gasket in, and put the motor back together.
