ML-TOYS
Spray some good penetrating all around the shaft and let is sit. Its probably corrosion holding it on.
Such as WD-40 rightSpray some good penetrating all around the shaft and let is sit. Its probably corrosion holding it on.
Such as WD-40 right
WD40 is NOT a penetrating oil, it's a water dispersant! Yes, it has a million uses but, penetrating & breaking down rust is NOT one of them, you need something like PB Blaster
The sanding begins got a random orbit sander 5 inch from HFi got 100 grit 120 grit and 220 grit that is all they had they did not have any 500 or 1000 grit
And neither does the rest of the real world......
Both of you need to pay some attention ^.....to what you are posting and what you are saying.....
Yes....they make 2000 grit sandpaper all friggin day long!!!!!!!!!!!! And they make all kinds of wet or dry grit sandpaper......do us all a favor....Cameron....since they don't make that fine a grit sandpaper for a 5" orbital.....just use the finest grit you can get....and PLENTY of water.....![]()
INDEED!!!
tongue and listen to your own advice!
maybe you're the one being too far away from the "real world" then...you are looking for 5" orbital sandpaper and 240 is about the finest I've seen.....
INDEED!!!
Doug honey I love you man.. but you watch yourtongue and listen to your own advice!
up to 1200 grit for 5" (125mm) orbital sanders are available at any (better) hardwarstore in germany!!
here's one online shop example :
http://www.conrad.de/ce/de/product/...0-125-mm-Bosch-Best-for-Stone-2608605123-5-St
As if carpainters don't use orbital sanders...
I admit, the 5000 and 7000 papers are not available for orbital sanders
(or at least, not that I know) and thus a bit 'off topic'
but that's it.
the link was meant as a "polishing cloth" result... nevermind!
And as it turns out, Cameron doesn't exactly need "orbital paper" only ... sooo yeah
INDEED!!!
but that's it.
