Just a quick aside on the drill bit -( well maybe two)..... what you have made is a mass produced drill with a name : it's called a brad point bit. Being a custom carpenter I use them quite frequently for their accuracy and clean cutting ability. The thing is- to the best of my knowledge- they are only manufactured to handle wood. I haven't run across any for metal.
As for the second aside- technically that is not a drill bit. (Either one). Technically a bit is on of those corkscrew looking things that goes in a brace which is basically a hand driven crankshaft affair. What those are are called drills. You put them in drill motors....It's been misused so much that it's now commonly accepted that you put a drill bit in a drill- but the old timers are rolling over in their graves every time you do. Just a little trivia. ...
Incidentdally- the other day someone asked me if I had a cordless screwdriver......I handed him a phillips......he looked at me puzzled. ...I said-" What??? -do you see a cord on that?"
Two stings to the right hand & one to the forehead... The worst part was I didn't even need to go near it, they were on completely the other side of the garage
Very true
