Nice work indeed..
but to be completely honest with you.. I expected that, you being a panel beater and such
One thing you learn as a panel beater is how to improvise...
If it's a good improvisation, then it goes in the
column. If it's bad, it goes into the "Half
" column....
Pat
Due to the unavailability of parts I'm looking at making a catcher setup. The catcher itself will be relatively simple but, it's the delivery system I'm concerned about...
The catcher itself will be mounted to the rear of the mower but, the grass chute is on the side so, I'll make an adaptor to fit on the end of the chute that then fits a PVC pipe which then goes into the catcher. The part I'm not sure about is the diameter of the pipe; will 4" be wide enough or will the grass clog it up? I can get 6" pipe but, because it's not as popular, it's way more expensive (around 3 times the price of 4"... if I pay for it...)
Thoughts?
PatI'll be watching this with interest
I need to make a catcher for my mower
If u go to Clark's rubber
They sell air Seeder hose for cheap
Like 4,6,8,10 in flexy hose
EDIT
Also I was thinking of putting a thermo fan on the catcher box to create a bit of vacume to draw the grass up
Based on your written description, I was trying to figure out how you turned a two flute drill bit into a three flute. Then, on photo #3, I see what you called a "three pointer", is what I've seen described as a "Trepanning Point". Don't know for sure if that's the correct & proper name for it, and I'm not really worried about it because the photo shows it just fine. And it works.
For anyone who stumbled over the drill sharpening side track we had on another thread recently, this is kind of a custom tool; it's basically a hack on a standard drill, where you grind the end flat, and then relieve the back edges between the center and the edges in the same fashion as you would a regular drill, leaving a center point to locate the bit, and two separate cutting tips at the outside edges. The goal is to cut around the outside of the spot weld, to disconnect it from the top piece, while causing as little distortion as possible to both pieces....
For anyone who would rather buy a tool for that, here in NA Eastwood Co. sells a double ended spot weld cutter, #11279 for around twenty bucks, plus shipping......
Pat
Fowler, almost all the heavy duty units I see it the summer have a dedicated engine to run the vacuum, just as you surmised.
There are several reasons I didn't bring it up....A] I have zero experience with them, and hence have little knowledge of the fine details that they need, and B] Fab is running on a Mc Budget, which means he really doesn't have one in the first place. I try to remember those facts when I try to offer advice....
Very professional work, now it needs some paint. Idea, instead of a grass cacther, install a mulching blade/blades.Very professional work, now it needs some paint.
Depends what type of stuff your cutting
Over here there a type of grass called Kykuyu
It is self seeding and can grow 3 inches in a day given the right conditions
It's very common for public areas and lawns because it'll live off almost no water over summer
And weeds can't touch it because it creeps too fast
If I don't take up the clipping then they blow into the garden beds and 10 days later u have kyk choking out roses
