Next...
fowler
Bullsbrook West Aus
no point in a new thread
got fed up with raking 3/4 of a acre
so when u was getting blades for the mower i noticed there was a newer mower on desplay with a catcher
turns out itll fit my mower
so i brought one
...but he has probably mowed his lawn 10 times in the time it has taken you to get to where you are now....:D:D:D
Probably true but, if you can't buy it, you make it, right? Mine will be the only mower of its kind with a catcher because they're not commercially available...
I've just been tinkering when I can the last few days but I seem to have progressed quite a bit. Apart from final sealing & anchoring everything together, I'm just about ready for a test run:
Pickup DONE
Rear support frame DONE
Chute DONE
Cover sheeting for turn around section almost DONE
I found a sealant/adhesive/gap filler combination which I'll use on all the sheetmetal before using blind rivets to hold it all together
More pics...
First test run today was a complete & utter FAILURE!
As I haven't made the catcher yet, I tied a breathable bag to the end of the pipe to collect the cuttings. As soon as I started the engine the bag inflated, as expected but, as I went on I noticed the bag was no longer inflated.
I removed the collector & fount it clogged with cuttings; it seems there isn't enough room in the 4" pipe for the cuttings to flow up the pipe; maybe I should've gone with my first thought & used 6" pipe...
Oh well, back to the drawing board... I have another idea I want to try, I'll get onto that in a day or three...
Oh yeah, in the process of discovering that the catcher doesn't work, the canopy frame snagged on something :)huh:) & tore it off...
fowler
Bullsbrook West Aus
I think u will find the breakable bag was the issue
If it inflated then there's too much restriction
Most bags are made of a shade cloth material
Try running it with no bag to see if it'll push it with no restriction
Just let it shot out the back
Ok and a possible off take from my production one
The funnel bit is located by a pin the slots in in a forward directionin the front idler wheel
The rest is simply pressed against a matching shape surface and held on with ocky strap things
So if I ever hit somthing (like a palm tree doh)
Then it just comes away
Or the bands stretch and u stop
Worst case I'd imagine the band clips would just break
I did try that, same result :(
Can you throw me some specs on your mower? Hp, cutting width & funnel diameter will do
:oops: :lolgoku:
What I'm thinking of doing next is use sheet metal to make a square(ish) funnel the size of the opening on the rear frame & rework the collector to suit
fowler
Bullsbrook West Aus
um im going to work in like 5 mins but quickly
17hp
42in deck
2 blades
170mm od pipe
the biggest differance i think
yours is like a funnel with a pipe exiting in the most logical direction
back
mine is more like the pipe goes straight into the desk
almost no funnel
then it exits straight out and gently curves around to the box
I think that's actually the problem, it's too much like a funnel...
After some quick calculations, the area of the deck opening is 24,320sq/mm & the area of the pipe is only 7,854sq/mm, less than 1/3 of the size...
fowler
Bullsbrook West Aus
Well with mine being designed by a big American corporation
OH&S is big
U dont want any one having to stick their hand down a small tube to clean grass out
They might set fire to them selves or somthing
I noticed with mine
If u push it too hard (tried to mow my road verve like 3 foot of love grass )
It simply leaves it behind as spies to blocking up
But it still manages 1 1/2 ft of kyke
