2013 - AusEx (AmEx Replica)
Wow. I thought we had it rough!
Nah, you guys have it easy... Think about it, I have to build a frame coz I can't buy one anywhere in the country :ack2:
Is that a #35 clutch?
Yes it is; 12t #35 clutch to be matched with a #35 70t axle sprocket.
Yes, I know, that's less than 6:1 (5.83333333333333:1 to be exact) but, not enough to matter...
Do you know what the factory gearing was on these things?
No idea...
Any luck with the bending company?
I haven't had a chance to update on that...
I measured the distance a few times just to make sure, went all the way out there (an hours drive) & showed the sales lady (the guy I'd been dealing with was off sick). She called in the guy who bent it who slapped a tape measure on it & it measured perfect :huh:
So, after much discussion on what to do, I decided to "adjust" the angles myself to achieve the correct height. The downside is, because they docked the ends (after I asked them to leave some excess), the overall length is now 4" short :censored: so I'll have to make some extensions; man, what a waste of time :mad2:
*Twin post*
I finally got my lathe onto it's new home & managed to turn up one of many spring retainers (so far)
... & bent the "C" brackets. Front end should be assembled in a few days :wai:
I have absolutely no idea what happened but, it was like being hit with a baseball bat; you know, that moment when you realise you have absolutely no comeback...
I have a piece of thickwall pipe I can turn down to use as plugs for the extensions
Yeah- going to war with a knife and finding out the other side's got guns... :surrender:
I had a supervisor that I very much respected, had a saying, "There are no problems, only solutions". Okay- so it's a bit Karate Kid, but it gets the point across. You can work through it, just put your mind to it.
Front Axle Done
Well, I've had some fun over the last few days spinning up the spring retainers for the front suspension.
Along with that, I bent some 30mm x 6mm flat bar to create the C brackets for the front spindles. Once I fitted the whole assembly together (C bracket, spindle, spring & retainers) it was time to weld them to the front axle.
Once I calculated the correct height, I used a length of RHS to establish a base line, then used a length of 65mm RHS as a spacer from the base line to the bottom of the stub axle (65mm being the desired height). A strategically positioned piece of 2mm scrap gave me exactly 2° negative camber.
Tack the C bracket to the axle, repeat on the other side & the front axle is complete.
I then put the wheels on the stubs & took a measurement; it's 4" wider than the rear axle... that won't do :censored:
So, I took it all apart, cut 60mm off each end of the axle, then put it all back together using the same process...
More progress on the front axle. I finished welding the C brackets to the axle beam which turned out quite well considering I was welding 6mm flat bar to 1.6mm wall tube...
I also sourced a pair of grade 8 bolts for the kingpins, some finishing touches on the bench grinder & the front end is done... well, apart from tie rods, mounting the axle to the frame, steering column... I think that'll be next.
Believe it or not, they're used valve springs, the lightest ones I could find. I called an engine reconditioning shop & the guy said "come & have a look". when I'd found what I wanted, I asked him how much & he said "see you later"...
Believe it or not, they're used valve springs, the lightest ones I could find. I called an engine reconditioning shop & the guy said "come & have a look". when I'g found what I wanted, I asked him how much & he said "see you later"...
Nice! They look like they are going to be perfect for the job.
freqster
League City, Texas
Looking great so far Fabroman. So do the springs on the spindles act as sort of a mini suspension/shock absorber? I haven't made mine yet and I may just copy what you did.
Ahhh- Valvesprings. If I had a nickel for every time I told somebody to use them for exactly that style of suspension...
Either way- you're looking good!
Orange Krate
North Texas
This is pretty awesome! It's like watching 70% of my go-karts being manufactured...(I got a lot of Manco frames)
Showoff! I should have taken pictures of the boy drilling out his minibike brake rotor bolt hole circle on the mill w/rotary table. I was too busy making sure he kept all his fingers LOL
