souperman000
wow, good work so far, really turning out slick.
You'll need to find a way to bracket that muffler securely. It has a lot of leverage on the engine, and you risk breaking the cylinder head.
Are your engine mounts slotted for chain adjustment? If so, you may have problems with the rubber mounts.
hmmm, i get what you mean,thanks for looking out,the metal box its mounted on right now had slots to adjust but didnt fit the duromax motor so i had to extend it by welding extra length of metal to it and drilling new holes for it,so right now it can only be mounted in one way and cannot be adjusted,will this cause another issue, if so what would be the best way to mount it you guys are way more experienced with these then me so im willing to listen and take any valuable advice thanks again
You could either hard-mount the engine (no rubber) on slotted mounts to allow chain adjustment, or, mount on rubber in non-slotted holes ans use a separate chain tensioner mechanism.
howd you make the air filter mounts?
That's just an awesome pair of rims! Looking good mate!
Where did you buy that exhaust? It's just epic!
